Edge gluing
« back to Joinery forum
Forum topic by lcurrent posted 12-03-2014 11:24 PM 1495 views 0 times favorited 10 replies Add to Favorites Watch
View lcurrent's profile
lcurrent
125 posts in 3783 days
12-03-2014 11:24 PM
Edge Gluing using the MortisePro Plus
https://www.youtube.com/watch?v=NxrFsIpWY8g
-- lcurrent ( It's not a mistake till you run out of wood )
10 replies so far
View jerryminer's profile
jerryminer
916 posts in 1409 days
#1 posted 12-04-2014 07:11 AM
Uhhhh—-why bother??
lcurrent
#2 posted 12-04-2014 06:58 PM
What it does
Have you ever glued up a top and had one board stick up a little out toward the center where you can not put a clamp ?
it puts a dowel or dowels in the same spot on both or
more so if there is a small difference in the boards that
will go to the down side of the table top so there is
not a lot of scraping and sanding .
View pizn's profile
pizn
13 posts in 1334 days
#3 posted 12-04-2014 07:35 PM
Any idea how much this thing costs?
View BinghamtonEd's profile
BinghamtonEd
2297 posts in 2337 days
#4 posted 12-04-2014 07:35 PM
- lcurrent
Not after I started using cauls. Seems like extra work.
jerryminer
#5 posted 12-05-2014 01:05 AM
- BinghamtonEd
Exactly!
117063 posts in 3544 days
#6 posted 12-05-2014 01:13 AM
I’ve been gluing up table tops for years without any connectors, I agree with the Ed glue is plenty strong enough without dowels ,this just adds extra unnecessary work and cost.
View wseand's profile
wseand
2796 posts in 3009 days
#7 posted 12-05-2014 01:39 AM
Dominoes, buscuits, now using a mortiser and dowels. Your best bet is to use cauls and good techniques to acheive a flat glue up. The mortiser might work well for smaller glueups but i would think it would be combersome for larger glueups.
I don’t use any alignment tecniques except for cauls and clamps but if you need them to get it flat then l say use them.
Rick Dennington
5808 posts in 3162 days
#8 posted 12-05-2014 06:19 AM
lcurrent
#9 posted 12-05-2014 06:27 AM
I dont why you would want to but you can put mortises, edge to edge on a 4 X 8 sheet of plywood together using loose tenons as one edge always stays the same
Mortisepropluse.com
View iminmyshop's profile
iminmyshop
284 posts in 1961 days
#10 posted 12-05-2014 07:44 AM
The above notes re: cauls are correct. Using cauls properly will align the parts during glue-up and put pressure across the entire length. Using biscuits and loose tenons to keep parts that are not well squared aligned will usually eventually fail as the wood’s memory is very strong.
-- http://www.alansfinewoodworking.com/
