Bosch 1617 height adjustment issue
Forum topic by ADHDan posted 12-03-2014 07:29 PM 4392 views 0 times favorited 22 replies Add to Favorites Watch
View ADHDan's profile
ADHDan
800 posts in 2106 days
12-03-2014 07:29 PM
Topic tags/keywords: question router
I’m having a problem with the height adjustment on my table-mounted Bosch 1617. Once I have the base set in one of the three detents on the motor, the motor can slide freely up and down within a range of about an inch. But when I turn the microadjust knob, the motor doesn’t seem to raise or lower and I can’t figure out why. The threaded rod does turn through the plastic clip that with the tab for the detents, so unless I’m missing a part I fear I might just be overlooking something really obvious.
I took some pictures to see if that might help troubleshoot. If anyone has thoughts I’d really appreciate it – and if you need more info, just let me know and I’ll circle back with answers. Thanks!
Edit: I looked at a diagram blow-out of the base and I’m wondering if I’m missing the retaining ring (part 70 at this site: http://www.ereplacementparts.com/bosch-1617-0601617039-shop-router-parts-c-128_1119_3107.html ). If that’s the case, I’m wondering whether I should just get a box of assorted clips from Harbor Freight or somewhere else for less than the cost of ordering one Bosch clip with shipping – http://www.harborfreight.com/300-piece-e-clip-assortment-67653.html. (Or if someone knows the size of that e clip I could just get a couple from a hardware store, presumably.)
-- Dan in Minneapolis, woodworking since 11/11.
22 replies so far
View pintodeluxe's profile
pintodeluxe
5658 posts in 2811 days
#1 posted 12-03-2014 07:39 PM
I have that router, and noticed the adjustment mechanism is a weak point. It is pretty funky how it works, as a spring loaded part just slides along the inner wall of the base to make adjustments. However, the threads are pretty fine, so I never needed to use the microadjust. To me they are a marketing gimmick, and not all that useful.
If the knurled plastic knob doesn’t adjust the height, then by all means get that fixed. I would stick with factory parts only.
Good luck resolving your issue.
ADHDan
#2 posted 12-03-2014 07:40 PM
Also, I’m going to ask a very dumb question but whatever. Assuming the problem is the e clip/retaining ring, what exactly does that clip do in the context of the router lift mechanism?
ADHDan
#3 posted 12-03-2014 07:41 PM
Maybe I mis-stated the problem – I thought the threaded rod was the microadjust. That’s what I’m having the problem with; when I turn the knob the threaded rod turns but it doesn’t raise or lower the motor. I edited my OP and title to clarify.
Just so I fully understand my tool, what is the microadjust feature if it’s not the threaded rod?
View Woodendeavor's profile
Woodendeavor
276 posts in 2604 days
#4 posted 12-03-2014 07:59 PM
I think you have the right idea. The knob and the measurement ring should be tight against the metal frame that holds the threaded rod. You should not have the gap that is shown in the first picture. It should always be tight like the second picture. Who did you buy the router from? I would expect them to fix it or replace it
ADHDan
#5 posted 12-03-2014 08:07 PM
I bought it off Amazon more than two years ago, so I doubt I’ll be able to get them to replace it.
When I looked at the parts diagram, I didn’t see a specific part that holds the knob and measurement ring tight against the frame – am I missing something? When the router is mounted in a table, can I just push up on the knob until it’s tight against the base before I turn it?
Basically, I’m wondering what the fix is here, if that’s the problem. Thanks!
ADHDan
#6 posted 12-04-2014 03:39 PM
Well, after doing a little research and thinking about what I’ll be using my router table for I decided it makes sense to upgrade to the 3.25hp Triton TRA001 and sell off my Bosch 1617. The Triton is beefier and has a much better lift mechanism, and the clincher was that Home Depot has it on sale for $225. Unfortunately, it’s out of stock at Home Depot but Rockler agreed to sell me the same router for $250 and throw in a $25 gift card to kind-of price match. I’d rather give my money to Rockler than Home Depot anyway.
Now I’ll just need to figure out where to drill out my Bosch RA1181 mounting plate to accept the Triton. If anyone’s encountered this before, I’d love to hear from you!
View OggieOglethorpe's profile
OggieOglethorpe
1276 posts in 2108 days
#7 posted 12-04-2014 04:01 PM
I used one of those in a table for years with great results.
Sorry for the stupid question, but you’re releasing the lock lever before trying to adjust, correct?
MrUnix
6710 posts in 2196 days
#8 posted 12-04-2014 04:08 PM
Did you determine if you were missing the clip on the bottom of the adjusting rod? It seems that would cause the problems you describe as the rod would be allowed to ‘float’ unsecured. If you don’t know the size needed, just take the adjusting rod down to your local hardware store and find one that works. If you are going to sell it off, you can usually get more for one that works properly :)
View MT_Stringer's profile
MT_Stringer
3168 posts in 3229 days
#9 posted 12-04-2014 04:29 PM
Also, I m going to ask a very dumb question but whatever. Assuming the problem is the e clip/retaining ring, what exactly does that clip do in the context of the router lift mechanism?
- ADHDan
If that clip is missing, that is your problem. Mine came off. Had to get a replacement from the hardware store.
View lumbermeister's profile
lumbermeister
128 posts in 1977 days
#10 posted 12-04-2014 05:24 PM
I fixed the missing clip issue a couple of years ago with a drill stop collar purchased for a couple of bucks from Home Depot. Been working perfectly ever since. That flimsy clip makes me wonder about the “vaunted” Bosch engineering.
ADHDan
#11 posted 12-04-2014 05:29 PM
Awesome, thanks all for the responses! I have some drill stop collars so I can try putting that on the rod to see if it fixes the problem, and if so I’ll get an e-clip for a permanent fix. Can you describe precisely where I should be putting the stop/clip? I feel stupid, but between your advice and the parts diagram I’m having a hard time visualizing where it goes.
(Oggie, I am releasing the lock lever before trying to adjust.)
I already did order the Triton router from Rockler, but they have a pretty good return policy so I figure I’ll fix the Bosch and see how it performs, compare it to the Triton, and then either return the Triton or sell the newly-fixed Bosch.
pintodeluxe
#12 posted 12-04-2014 05:48 PM
Darn, now you’ll have to keep both routers.
Good choice on the Triton.
As far as the Bosch, isn’t it just a missing spring clip? It looks like a snap ring.
Toolpartsdirect has a schematic… it is called a retaining ring part #70 and costs 66 cents.
http://www.toolpartsdirect.com/bosch-1617-039-shop-router-060-1617-039.html
MT_Stringer
#13 posted 12-04-2014 06:02 PM
- lumbermeister
Yep, that is what I used on one of the bases (I have two).
Your are going to love the Triton. I can tell you that ahead of time.
I have both routers in a table, but theses days, The Triton gets the most use.
http://lumberjocks.com/projects/101964
ADHDan
#14 posted 12-04-2014 08:36 PM
Darn, now you ll have to keep both routers.
As far as the Bosch, isn t it just a missing spring clip? It looks like a snap ring.
- pintodeluxe
That’s what I thought, but isn’t that clip at the top of the threaded rod? Other posters (e.g. MrUnix) referenced a clip on the bottom of the rod that keeps it from floating unsecured. I’m going to be honest, I feel like I’m missing something completely obvious – probably because I’m having a really difficult time visualizing the mechanics of the lift without actually seeing a properly-working model in action.
Can you guys help set me straight?
MrUnix
#15 posted 12-04-2014 10:07 PM
LOL.. ok, if you have it mounted in a table upside down then the bottom is what you probably consider the top. According to the parts diagram, that adjusting rod has a knob on one end (top if held in the proper direction, #48), runs down through the indexing mechanism (#49 et al), and then has a clip on the end (part #70 in the diagram) that holds it in place. There should be a groove machined into the end of the rod for the clip to snap into just past what looks like a threaded section of the rod. Here is the relevant portion of the parts diagram:
Hope that makes sense.
