Vietnam Lacquer Art on Wood
Forum topic by duongthuy posted 283 days ago 324 views 1 time favorited 1 reply Add to Favorites Watch
View duongthuy's profile
duongthuy
4 posts in 387 days
283 days ago
Topic tags/keywords: lacquer vietnam lacquer handicrafts hand made handmade
Through years of experience and experimentation, the artists use the addition of other substances such as plant material ash, crushed eggshells, gold and silver to embellish their works. These additional substances help the modern artists to express themselves fully and to further add creativity and individuality of style to their art works.
The board
The artists buy the boards ready-made from suppliers. They come in a variety of sizes.
The core of the board is made from plywood. One layer of lacquer is applied to the plywood which is left to dry. Next, thin cotton cloth soaked in clay are attached to both sides of the plywood. After the cotton/ clay mixture dry, the board will be smooth.
The process is performed five times. Layers of black lacquer are then applied, polished. Thus, the final product appears as a piece of black board, very smooth and durable. It consists of several layers, is very resistant, and will not crack due to fluctuation in temperature or humid. It may be wrap slightly due to changes but it is quite easy to straighten it again, as it remains flexible.
The lacquer and colors
Lacquer is a clear sap coming from any of six species of trees growing in Vietnam.
Lacquer is harvested in the same way as rubber, by making and incision and letting the sap flow. Fresh lacquer is whitish, and turns brown upon exposure to air. It should be noted that lacquer is not a harmless substance. It is a common skin irritant and a cause of contact dermatitis, as well as being potentially corcinofenic. Black lacquer stems from a chemical reaction between lacquer and iron, and results from stirring the lacquer with iron rod for a few days. Lacquer will be mixed with various natural or artificial dyes to produce the colors the artists want. Several shades of red are extracted from a naturally occurring red mineral, cinnabar( mercuric sulfide). White produces from eggshell. Eggs from ducks are used because they have a better structure than hen’s egg. The eggshells are cleaned and sometimes even burned to obtain a brownish tinge. Most bright colors come from artificial dyes.
Other Materials
Several other materials may be used to make lacquer paintings, some of the most common being gold leaf. Silver is used below the layers of colors to create and effect of immense luster. Gold leaf, on the other hand is often applied as the final layer. An interesting use of gold leaf appears as bright light flowing through the window. A range of other materials may also be used such as shells, sand, epoxy and clay.
Applying lacquer and polishing
Making a lacquer painting is a long and arduous process. It may take several months depending on the specific technique of the artist and how many layers of lacquer are included.
Firstly, the composition of the painting may be drawn with chalk on the board, white color is added through the use of eggshell. A pattern is carefully carved in the board. Minute piece of clean eggshell are glued to the cavities, and the surface is then made smooth. Clean lacquer is applied and left to dry, and the pattern is then polish.
A basic lacquer layer of colorful lacquer is applied to the board and left to dry. Silver leaf is stuck to the lacquer and cover the silver leaf. New layers of colored lacquer are painted with a brush, each with different color. In between, clear lacquer is also applied. The artist sometimes applied up to ten layers or more of colored and clear lacquer. The paint is left to dry between each application and the layers are also smoothed.
The most important of the process, however, takes place after the final layer has been applied. The artist will rub and polish different parts of the painting until he obtains the preferred colors for various parts of the painting. Since different colors are located in different layers, rubbing must be done with great care by using fine sand paper and mix of charcoal powder and human hair.
The artist must remember in what layer he puts the color and has to be extremely careful not to rub too hard because the painting will be irretrievably spoilt if he rubs through the layer he wants to keep a specific color.
Care
A lacquer painting is very durable. The board is hard and strong and is not easily damaged. The surface of clear lacquer is protective and the painting can easily be polished by the palm of the hand to make it clearer and more lustrous. A Vietnam lacquer painting is truly a piece of art that may last for generations.
14160 posts in 1057 days
275 days ago
this is really interesting!
thanks for posting this.
