What router bit do you use to cut hand-grips on bottom of cutting board?
Forum topic by nicole72 posted 12-03-2014 12:15 AM 6225 views 1 time favorited 5 replies Add to Favorites Watch
View nicole72's profile
nicole72
23 posts in 2659 days
12-03-2014 12:15 AM
Topic tags/keywords: question trick help router pissed off i cant do it by myself
Help please! I have spent all day in the shop trying to figure out how to route handles onto the bottom of a cutting board!! I have a 19”x30” board made for a family member who cooks a lot of brisket and wanted to have some hand-holds routed on underside so board would be easy to pick up…..I have tried and failed for hours in countless pieces of scrapwood to get this right…I need to know what kind of bit do yall use for the router to do this first off, because I have tried several and made a jig using a hinge mortise kit and I am failing! Any advice is appreciated thank you!
-- Nicole
5 replies so far
View JAY Made's profile
JAY Made
202 posts in 2284 days
#1 posted 12-03-2014 12:35 AM
I use 1 of two different bits depending if I want the finger grips on the bottom of the board or in the middle
1. Grizzly C1261 Bottom Cleaning Bit This bit limits the cutting surface to just the top.
2. Whiteside Router Bits 1411 Round Nose Bit This bit allows the user to use both sides of the board.
-- We all should push ourselves to learn new skills.
View Tony_S's profile
Tony_S
953 posts in 3323 days
#2 posted 12-03-2014 12:37 AM
You can use a large cove bit with a bearing….
http://www.freud.ca/English/Pages/Bits/EdgeTreatment/Cove/Cove.html
Or a core box bit…
http://www.freud.ca/English/Pages/Bits/Grooving/RoundNose/RoundNose.html
(I got a laugh out of your topic tag btw)
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View ElChe's profile
ElChe
630 posts in 1576 days
#3 posted 12-03-2014 02:04 AM
If you want a smooth rounded finger hold, a bowl and tray router bit or a round nose bit will give you a clean bottom. They sell them in various diameters and with or without a guide bearing.
View DIYaholic's profile
DIYaholic
19752 posts in 2915 days
#4 posted 12-03-2014 02:22 AM
I used a cove bit with a bearing, as it was the only bit I had….
View Steve Peterson's profile
Steve Peterson
395 posts in 3322 days
#5 posted 12-03-2014 07:37 PM
I used a 1” diameter ball nose bit raised about 1/4”. I used a featherboard to hold the board upright. Turn the board around and make a second pass to keep it perfectly balanced.
It is useful on the ends as a handle and also good on the sides to brush crumbs off into your hand.
-- Steve
