So I'm looking to sharpen nail - are they all created equal?
Forum topic by ToddJB posted 12-02-2014 06:46 PM 1307 views 0 times favorited 11 replies Add to Favorites Watch
View ToddJB's profile
ToddJB
7944 posts in 2128 days
12-02-2014 06:46 PM
I have a need to sharpen a nail! When googling “nail hardness” my results are filled with cosmetic pintrest articles, which are entertaining but not at all helpful for this application.
So, if you were looking to sharpen a nail that retained a pointy tip what sort of nail (material) would be ideal for such an application?
-- I came - I sawed - I over-built
11 replies so far
View Mauricio's profile
Mauricio
7144 posts in 3149 days
#1 posted 12-02-2014 07:30 PM
is this a hardened nail where files skate off? If so I would use a diamond stone or paddle of some kind. I think there are fish hook sharpeners that could work also.
View JayT's profile
JayT
5627 posts in 2209 days
#2 posted 12-02-2014 07:31 PM
If you can find a masonry nail small enough for what you want, that would be ideal. They are hardened steel.
Is this for a marking gauge or some other fancy project?
View jdh122's profile
jdh122
1009 posts in 2815 days
#3 posted 12-02-2014 07:46 PM
What Jay said – the only hardened nails I know of are concrete and masonry nails. It’s why they say not to strike them with a hardened hammer, apparently there’s a risk of small pieces of the hammer or nail fracturing off.
-- Jeremy, in the Acadian forests
ToddJB
#4 posted 12-02-2014 08:01 PM
Masonry nails it is! Thanks, gents!
Would the nails in a carpet strip designed for concrete be the same? Because I believe I have some of those floating around.
View JayT's profile
JayT
#5 posted 12-02-2014 08:07 PM
- ToddJB
Should be. Those are just masonry nails embedded in the tack strip.
View Hammerthumb's profile
Hammerthumb
2844 posts in 1973 days
#6 posted 12-03-2014 12:11 AM
If you need something a little larger Todd, send me a PM. I have concrete nails used to attach 3/4” plywood to concrete.
-- Paul, Las Vegas
View ElChe's profile
ElChe
630 posts in 1334 days
#7 posted 12-03-2014 02:43 AM
I call bull. I wanna know why Todd is sharpening a nail. :)
View crank49's profile
crank49
4030 posts in 2968 days
#8 posted 12-03-2014 03:14 AM
Cut type masonry nails are very useful for all sorts of cutting and carving tools, even small chisels.
I have used them for years.
Also, I never throw away small HSS burrs and drills when they break. They can be ground into other usefull shapes as well.
View Ub1chris's profile
Ub1chris
116 posts in 1378 days
#9 posted 12-03-2014 03:40 AM
All the nails I’ve ever bought come pre-sharpened :)
Chris
ToddJB
#10 posted 12-03-2014 02:03 PM
Thanks all.
- Hammerthumb
Thanks for the offer Paul, but I believe I’m all set.
View BinghamtonEd's profile
BinghamtonEd
2298 posts in 2367 days
#11 posted 12-03-2014 02:38 PM
If you could chuck it up in the drill press or handheld drill, it might make sharpening easier, as well.
