How would you sharpen this plane.
« back to Hand Tools forum
Forum topic by Joel_B posted 12-01-2014 10:22 PM 1008 views 0 times favorited 6 replies Add to Favorites Watch
View Joel_B's profile
Joel_B
341 posts in 1345 days
12-01-2014 10:22 PM
Thinking about buying one of these cornering planes but assuming the blade would need some work initially and sharpening down the road. Not sure how to sharpen a blade with a curve in it.
-- Joel, Encinitas, CA
View jmartel's profile (online now)
jmartel
7802 posts in 2114 days
#1 posted 12-01-2014 10:52 PM
A dowel that’s matched to the radius and some sandpaper to wrap around it.
View JayT's profile
JayT
5587 posts in 2175 days
#2 posted 12-01-2014 10:59 PM
For any plane iron with a profile, Paul Sellers recommends cutting the profile in board first, when the plane is sharp. When the iron needs touching up, load the cut profile on the board with honing compound and pull the iron over it. Haven’t tried it, yet, but makes sense to me.
View 7Footer's profile
7Footer
2569 posts in 1913 days
#3 posted 12-01-2014 11:19 PM
^^oooh Jay, nice, haven’t seen that Sellers vid yet, does make sense though, awesome idea.
Also you could use a slipstone.
-- http://www.youtube.com/nrk411
View JayT's profile
JayT
#4 posted 12-02-2014 01:37 AM
I don’t know if he’s done a video on that. Probably has, but I haven’t seen it if so. Picked up the tip at the Woodworking Show a couple years ago at one of his sessions.
View Don W's profile
Don W
18685 posts in 2532 days
#5 posted 12-02-2014 01:43 AM
JayT’s suggestions works as long as you remember to cut the profile before it gets dull, then remember where you put it. I wish I was that organized. I’d sharpen it with my oil stone for the flat, then use jmartel dowel (a bolt, rod or anything the right diameter) trick.
View JohnChung's profile
JohnChung
407 posts in 2038 days
#6 posted 12-02-2014 05:57 AM
+1 JayT trick
