Stanley Rule and Level Co No 29 find
« back to Hand Tools forum
Forum topic by Brodan posted 11-30-2014 10:52 PM 3182 views 0 times favorited 6 replies Add to Favorites Watch
View Brodan's profile
Brodan
142 posts in 1424 days
11-30-2014 10:52 PM
Topic tags/keywords: plane
I bought this Stanley Plane while picking through an “antique” shop. Not knowin much about it, I gave $47 for it. I’ve included links to a few pics of it. Looking for any information or a source of info.
As my plan is to use this plane, and this is new to me…. I’d appreciate any suggestions anyone has for checking it out and putting it into good useful shape.
-- Dan, TN
View kdc68's profile
kdc68
2688 posts in 2398 days
#1 posted 11-30-2014 11:37 PM
Your plane looks to be a Type 7.
Look up member Don W here on Lumberjocks for his blogs.
He has a website Time Tested Tools as well.
Both will provide info you may need.
-- Measure "at least" twice and cut once
View Rick S.'s profile
Rick S.
10325 posts in 3154 days
#2 posted 12-07-2014 04:16 AM
Other than the following from this Site http://www.toolexchange.com.au/
This the best I can do right now. They have TON of info on there if you want to have a Look See and wade through it.
Hope it’s of some help.
Rick
-- It is not necessary for Some People to turn OFF the LIGHT to be IN the DARK!
Rick S.
#3 posted 12-07-2014 05:13 AM
Also these ones VIA a “Google Image Search”. Which could go on forever ….LOL… They are all 29’s.
NO! Just broke my own Rule! Last time “Brodan” was on here was when he posted this. Nov. 30/14. If I get a Reply, that will be a small Miracle! HORSE DROPPINGS!!!
Brodan
#4 posted 12-07-2014 03:13 PM
Thanks, I appreciate the info.
I disaasembled and saw that all of the parts function. With out doing anything except reassembling, I used this plane to reasonably straighten the edge of 7 foot lengths of 4/4 rough red oak. Although a novice to fine woodworking and hand tools, the plane cut cleanly producing .004 thick shavings. So it seems to be “operational” The “sole” seems to be slightly convex and I think I need to flatten before being able to truly produce a straight/ flat surface. Since the mouth is narrow and hasn’t been repaired, I’d like to get this right the first time, so I take minimum stock off of the sole and have minimal affect on the opening. Any advice on the best way to so this? Thanks Dan
-- Dan, TN
View bandit571's profile
bandit571
21085 posts in 2805 days
#5 posted 12-07-2014 03:24 PM
This one is a Stanley #31
24” long, with a 2-3/8” wide iron.
I used a #6 iron bodied plane to flatten the sole on mine. Same as an iron sole, mark a bunch of lines across the width of the wood sole. THIN shavings until the lines are almost gone.
View Don W's profile
Don W
18946 posts in 2689 days
#6 posted 12-07-2014 03:41 PM
if its already taking fine shavings, I wouldn’t touch the sole. The #29 isn’t extremely valuable, but yours is in exceptional shape.
check out supertool.com for some more information.
