Router Bit Question
Forum topic by EdsCustomWoodCrafts posted 11-30-2014 09:12 PM 983 views 0 times favorited 10 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
746 posts in 1247 days
11-30-2014 09:12 PM
I have a router table and sometimes when I’m cutting a dado in some stock the bit keeps raising out of the router collet and deeper into the wood.
I’ve tried the obvious fixes for this for example take more passes to cut the depth but I don’t think 1/4” is too deep…
Please help!!!!!!
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
10 replies so far
View johnstoneb's profile
johnstoneb
2786 posts in 2077 days
#1 posted 11-30-2014 09:17 PM
You are not getting the collet tight enough to hold the bit the collet may be dirty also.. Clean the collet, all surfaces inside and out and on the router and make sure the shaft on the bit is clean and dry also. I actually had a bit come all the way thru the material once. Now I make sure the bit is clean and dry and there is nothing in the collet. I haven’t had any problems since I started doing that.
-- Bruce, Boise, ID
View RogerInColorado's profile
RogerInColorado
321 posts in 1858 days
#2 posted 12-01-2014 12:37 AM
If I’m after precision, I won’t take more than 1/8 inch at a time. If you are using a 1/4 inch shank bit, then cutting a quarter of an inch of material at a time is way too much unless you love chatter marks. As to your description, I would concur that a slipping bit is the result of a dirty or loose collet, but usually the bit gets pushed farther into the collet, not further out.
View Holbs's profile
Holbs
1795 posts in 1933 days
#3 posted 12-01-2014 02:18 AM
wait a second…
are you guys saying a router bit CAN rise or lower from the router collet?
-- The Carpenter Bee is derived from the Ancient Greek word wood-cutter
View ElChe's profile
ElChe
630 posts in 1240 days
#4 posted 12-01-2014 02:27 AM
Yes. If the collet isn’t tight you can literally have a carbide or HSS Frisbee if the router bit falls out. Ed make sire the collet is clean and tight. No need to overtighten it. But it needs to be snug. 1/4” pass with 1/2” shank bit seems reasonable. With a 1/4” shank may be too much. Also make sure the router table isn’t flexing/sagging. Good luck.
View AlaskaGuy's profile
AlaskaGuy
3912 posts in 2213 days
#5 posted 12-01-2014 02:46 AM
What brand of router bit are you using. I have read where lesser brands sometime have slightly smaller shaft diameters do to poor quality control.
Holbs
#6 posted 12-01-2014 04:06 AM
Didnt know a router bit can slide up or down while in the collet. I always blow away dust and inspect the collet and router bit shaft after every use. Hmm… maybe I should drop the collets into a cleaning solution every so often.
Good to know this. I like being safe :)
View Paul's profile
Paul
721 posts in 1469 days
#7 posted 12-01-2014 04:33 AM
No, a router bit can not rise if correctly seated in your collet. If you blow your collet with compressed air and correctly seat it, it can not rise on its own. If you have a magic router bit rising from your collet your doing something wrong.
Paul
View pintodeluxe's profile
pintodeluxe
5566 posts in 2717 days
#8 posted 12-01-2014 04:41 AM
Ed,
I have had that happen once or twice over the years. Usually using a 1/2” collet will fix the problem. Occasionally you have to clean sawdust out of the collet. If all else fails, try replacing the collet and bit.
I find using 2 wrenches to tighten the collet is more effective than using collet locking buttons.
View greg48's profile
greg48
593 posts in 2661 days
#9 posted 12-01-2014 04:11 PM
Ed,
It seem’s that you already have good advice and I can add nothing here regarding your problem of loose bits in the collet. However, here’s a little tip I’ve read somewhere and I follow the advice regularly. Do not seat the bit shank in the bottom of the collet before tightening. Instead lift the bit slightly off the collet floor, then tighten. As I said this may not solve your tightening woes, but it will eliminate the problem of jammed bits that won’t come out.
Happy routing and be sure to wear hearing protection.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
View jeffswildwood's profile
jeffswildwood
2822 posts in 1881 days
#10 posted 12-01-2014 05:46 PM
I had this happen once. 1/4 inch spiral up cut bit. actually dug in real bad. After I checked I had forgotten to even tighten the collet. One of those woops moments!
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
