Underside of a Delta 37-190 jointer
Forum topic by jshattoc posted 11-30-2014 05:35 PM 1152 views 0 times favorited 1 reply Add to Favorites Watch
View jshattoc's profile
jshattoc
13 posts in 2324 days
11-30-2014 05:35 PM
I was hoping someone could do be a big favor. I had to replace the bearings on my 37-190 jointer. There is a little dust flap with a sponge on it that is attached via the same screws as the cutterhead bearing blocks. So naturally, that came off when I removed the cutterhead. I cant for the life of me figure out how to get that flap back on, even though there’s only 4 different ways it could do. It somehow interfaces with the dust chute that the motor mounts on, but I cant quite figure it out. Would someone be able to take a picture of the underside of this jointer, or describe how that flap is situated? It would really help me out.
1 reply so far
View gabesgarage's profile
gabesgarage
3 posts in 1172 days
#1 posted 04-06-2015 04:35 PM
I am having the exact same problem. Were you able to figure it out? Does the foam piece end go up into the machine? It seems to be the only way it fits, but is that too close to the cutter? thanks.
Gabe
