25 inch planer $2500
TECHNICAL SPECIFICATIONS OF 630-MM (25 INCH)
• Length of table-----------------------------630×1000mm.
• All cast
• Width stock will plane-------------------------630 mm
• Height of the front table------------------------800 mm.
• Shaft speed-------------------------------5500 rpm
• 4 knives of--------------------------------630×35 x 3.5 mm
• Maximum stock removal-----------------------8 mm
• Minimum length of wood-----------------------280 mm
• Feed motor--------------------------------2 - Hp
• Shaft D----------------------------------120 mm.
• Feed speeds------------------------------- 6 , 9 , 12 , 18 m./Min
• Voltage----------------------------------380 V / 3 Phase.
• Motor-----------------------------------10 HP
• Overall dimensions--------------------2600mm x 700mm x 900 mm
• Electrical System: Star-Delta Starter
• Net weight--------------------------------1200 Kg.
• Gross Weight------------------------------1500 Kg
16 inch operations combined $2500
TECHNICAL SPECIFICATION FOR 400-MM (16 INCH) COMBINATIONS MACHINE
1) SURFACE PLANER
• Length of table---------------------400×1920mm.
• All cast
• Shaft speed-----------------------4000 rpm
• 3 knives of------------------------400×35 x 3.5 mm
2) Thicknesser
• Maximum stock removal---------------8 mm
• Table length-----------------------400×700 mm
• Feed motor-----------------------2 - Hp
• Shaft D-------------------------120 mm.
• Feed speeds-----------------------6 Mt./Min
• Width stock will plane----------------400 mm
3) Mortiser
• X travel-------------------------200 mm
• Y travel-------------------------160 mm
• Z travel--------------------------200 mm
• Dimension-----------------------280×540 mm
• Right side mortising bit----------------3/20 mm
• Voltage 380v/ 3 phase
knife grinder $1000
TECHNICAL SPECIFICATIONS:
• Length of table-----------------------800×40 mm.
• Stroke----------------------------650 mm
• Chain driven
• Electrical 3 phase 380 volt
The links in the first post are working for me.
