Craftsman 101.06242 lathe restoration
« back to Woodturning forum
Forum topic by Dror posted 11-29-2014 05:48 PM 5177 views 0 times favorited 45 replies Add to Favorites Watch
View Dror's profile
Dror
60 posts in 1322 days
11-29-2014 05:48 PM
Topic tags/keywords: 10106242 wood lathe restoration oneway talon
Hi,
I had in the past asked members for information regarding their lathes and used some of the information to restore an old lathe.
So the project is finished and thanks!
The clicking noise is a bad bearing that does not fit the lathe.
View on YouTube
45 replies so far
View rayn's profile
rayn
174 posts in 3122 days
#1 posted 11-29-2014 06:34 PM
Sweet!
-- Ray,Iowa
View Rick_M's profile
Rick_M
11095 posts in 2283 days
#2 posted 11-30-2014 05:24 AM
Nicely done and I like the color. Did you replace the bushings with roller bearings? Also, how do you like that round drive belt? I’ve seen those before but if memory serves they were expensive so I went with a standard V belt on mine.
-- http://thewoodknack.blogspot.com/
View Dror's profile
Dror
#3 posted 11-30-2014 06:01 AM
Hi, thanks guys.
I replaced the bushings with new ones but not with roller bearings. I am not sure if that possible, is it?
The color is RAL 5015.
The belt is 1/4” and was not expansive but not simple to weld. It is very quiet and easy to stretch onto the pulley.
View dhazelton's profile (online now)
dhazelton
2686 posts in 2200 days
#4 posted 11-30-2014 02:08 PM
Well done. Where do the DC motor and controller come from?
View Dror's profile
Dror
#5 posted 11-30-2014 02:12 PM
thanks it is a 3 phase 230v motor. ebay.
Rick_M
#6 posted 12-01-2014 07:37 AM
Hi, thanks guys.
Don’t know but it’s an interesting idea. I have a Goodell Pratt with bushings and it has been in the back of my mind to find out if they can be swapped for roller bearings.
View Trabiman's profile
Trabiman
9 posts in 2245 days
#7 posted 06-20-2015 11:56 PM
just recently picked up one of these old Dunlap/Sears lathes. Do you have other pictures of the lathe throughout the process? How hard was it to find parts? The one I have is missing a couple things…
-- Brian from Westfield, IN
Rick_M
#8 posted 06-21-2015 06:36 AM
Depends on what’s missing. Ebay is unfortunately, your best bet. Everything you need will probably be on there and each part will cost as much as your lathe.
View Dror's profile
Dror
#9 posted 06-21-2015 07:43 AM
Hi
I have no images that I can find. If I find then I will post them.
I think you are going to find most parts are ok just clean and grease the ones in the tailstock and it will be like new.
Take the headstock apart: Release the spindle lock ring with the left hand thread – left side and right hand thread on the right side and release the lock screw in one the pulley.
If the oilite bushings are good the spindle will have no play if pulled up and down. If it moves, then these are not expensive on ebay just make sure you order the correct ones. There are the two thrust bearings you need to inspect and see if they are original and in good shape.
More than that it cleaning, paint/rust removal and finish are more matters of cosmetics.
When refitting the spindle after making sure there is no or almost no play. Start with the lock ring on the right it is a good idea to secure it as strong as you can and add strong locktite. Do it before fitting the spindle. Then take it through a metal lathe to face the shoulder that supports the headstock. This is the most important tip to make this lathe as accurate as it can be.
Dror
View MrUnix's profile
MrUnix
6331 posts in 2102 days
#10 posted 06-21-2015 08:27 AM
According to the parts list in the manual, the only bearing on that lathe is a thrust bearing (PN# L2-20)... the spindle rides in bushings (PN# L2-14). The bushing size isn’t specified, but it should be pretty standard. They are a PITA to replace though, so hopefully yours are still in good shape. For the thrust bearing, you may be able to clean and re-pack it yourself if it’s not too worn out. If it needs to be replaced, the VM Wiki has this about the bearing:
Original Thrust Bearing: SKF 465233 (ID: 1-7/16”, OD: 7/8”, W: 13/32”); Atlas part number- L2-20
(Although, I think the OD and ID above are reversed)
I know you can get needle thrust bearings in that ID/OD (but thinner), so you should be able to find ball thrust bearing as well.
View Chris_'s profile
Chris_
39 posts in 3490 days
#11 posted 11-23-2015 02:51 PM
I just bought one of these. Thanks for the post.
Where did you get the rubber belt for this?
I’ve got a number of tools that could benefit from these types of belts.
thanks
Chris
-- Chris
View Dror's profile
Dror
#12 posted 11-23-2015 03:06 PM
I think I got it from Amazon
Chris_
#13 posted 11-23-2015 03:12 PM
Did you get the raw stock, or preformed belts?
- Dror
-- Chris
View Dror's profile
Dror
#14 posted 11-23-2015 03:26 PM
I am not sure I understood.
I used heat to weld it and made the needed size.
Chris_
#15 posted 11-23-2015 03:31 PM
- Dror
Okay, so you got raw stock and made your own.
thanks
-- Chris
showing 1 through 15 of 45 replies
