shelf mounting with metal studs?
Forum topic by rhybeka posted 11-29-2014 03:19 PM 977 views 0 times favorited 10 replies Add to Favorites Watch
View rhybeka's profile
rhybeka
3644 posts in 2997 days
11-29-2014 03:19 PM
Topic tags/keywords: shelving hanging walls blocking steel studs
I’m beginning to feel a bit like a doofus having metal studs used in our basement remodel – sounded like a good idea at the time just in case we ever had water damage…I don’t really want to be ripping out six ft of drywall to run blocking where I now need to install about a six foot run of shelving. It’s only going to hold legos so not a ton of weight – but enough. I’m debating on the best way to mount it – should I lessen the load to 2ft runs (six inches wide) instead of running one six ft shelf? molly bolts or a french cleat? or possibly something more industrial like iron piping ends (idea from pinterest) Most likely the wood will be 1x oak or possibly knotty pine.
-- Beka/Becky - aspiring jill of all trades, still learning to not read the directions.
10 replies so far
View Bogeyguy's profile
Bogeyguy
548 posts in 1944 days
#1 posted 11-29-2014 04:02 PM
French cleats anchored into the metal studs.
-- Art, Pittsburgh.
View klassenl's profile
klassenl
184 posts in 2535 days
#2 posted 11-29-2014 04:14 PM
If you make sure you have the correct screws you should be fine.
-- When questioned about using glue on a garbage bin I responded, "Wood working is about good technique and lots of glue........I have the glue part down."
View Grandpa's profile
Grandpa
3259 posts in 2551 days
#3 posted 11-29-2014 04:48 PM
French cleats. They anchor easily and hold a bunch.
View TheFridge's profile
TheFridge
8673 posts in 1362 days
#4 posted 11-29-2014 06:55 PM
Toggle bolts, Sheetrock screws through the studs.
View timbertailor's profile
timbertailor
1594 posts in 1300 days
#5 posted 11-30-2014 01:00 AM
Just break down and re-sheath the wall in plywood. That way you can hang whatever you want, wherever you want.
rhybeka
#6 posted 12-01-2014 04:27 PM
LOL, thanks Brad – but no – I’ll leave the pretty painted wall intact :) The room itself is a home theater room so it’s not a work area. I picked up some nice pine boards for this project – deciding if I want to distress them or not :D Thanks for the input all! I’ll post pics once I get them hung.
View Earlextech's profile
Earlextech
1160 posts in 2566 days
#7 posted 12-01-2014 04:34 PM
As long as you don’t strip the screws in the studs you won’t have any problem.
View longgone's profile
longgone
5688 posts in 3184 days
#8 posted 12-01-2014 04:35 PM
Never used metal studs…but why wouldn’t they hold since they are metal? Must be some very thin metal used in them…
View MT_Stringer's profile
MT_Stringer
3136 posts in 3107 days
#9 posted 12-01-2014 04:41 PM
Does the shelf have a back for support?
I think you will be fine with two screws in each stud. If needed, use toggle bolts where there is no stud available.
A shelf like this?
For drywall anchors, I have been using these. They work great.
http://www.amazon.com/Toggler-Snaptoggle-Toggle-Drywall-Molly/dp/B005C4YE4M
I got mine locally from the big blue box store.
Hope this helps.
Mike
rhybeka
#10 posted 12-02-2014 12:53 AM
honestly Mike, I haven’t really designed the shelves yet… I was leaning towards floating, but I also thought about ‘industrial’ to incorporate a metal element (like this but with 1x maybe? http://media.restorationhardware.com/is/image/rhis/prod1860679?$l-pd1$&illum=0)
now I’m thinking something minimal – if I could get away with screwing a french cleat piece into the back of the 1×6 or 1×8 and not think there’d be too much weight pulling against it I’d probably do that.
