Clearview Dust Collector noise
Forum topic by mbs posted 11-28-2014 03:58 AM 1354 views 0 times favorited 6 replies Add to Favorites Watch
View mbs's profile
mbs
1656 posts in 2935 days
11-28-2014 03:58 AM
I’m installing a CV in the corner of a 20’ x ‘30’ shop. I think it’s the 1800 model with the 15” impeller. With the wynn filters it cranks out 88 dB. I need to vent into the shop. I’ve looked at the clearview website which has some good info. I’m wondering what you guys have done that’s worked well to reduce the noise (and what you’ve done that hasn’t worked well).
-- Sorry the reply is so long. I didn't have time to write a short reply.
View TheFridge's profile
TheFridge
9444 posts in 1481 days
#1 posted 11-28-2014 04:07 AM
Not a whole lot aside from making it’s own closet and insulating it.
View mbs's profile
mbs
#2 posted 11-28-2014 04:09 AM
2×4 with fiberglass? how much difference in dB did you get?
View ducky911's profile
ducky911
237 posts in 2784 days
#3 posted 11-28-2014 03:53 PM
- mbs
down below 70db with all gates closed. But the clearview moves alot of air so when you open a gate the dbs go up from the moving air swish.
View Steve Peterson's profile
Steve Peterson
375 posts in 3077 days
#4 posted 11-28-2014 06:19 PM
I built a closet around my CV with a large door across the entire front wall and a smaller door just large enough to access the drum. The large door does not need to be opened very often, so it can be just a panel screwed in place. The closet was simple 2×4 framing with fiberglass insulation and plywood skin. Sheetrock would probably be slightly quieter.
I have a dividing wall between the drum and the filters, so the air leaving the filters has to travel past the motor (keeping it cool). This worked well.
I ran the exhaust behind my wall mounted workbench. I lost a bit of drawer depth, but think that it helped dampen some of the exhaust noise. Other solutions include a baffle so the air has to travel around a few corners before exiting. Try to keep the exhaust area at least twice the area of the ducts or else it will be too restrictive. 6” by 12” should be good.
-- Steve
View mbs's profile
mbs
#5 posted 11-29-2014 12:30 AM
Thanks for the suggestions. I started my closet like Steve suggested. Using 2 x 4 and staggering the cross braces. Orderd ROXUL safe and sound to help insulate. Also bought 4×8 sheets of sound barrier. Not sure if I will make the dividing wall or not. I’m also not sure how I’ll finish the exterior (plywood, drywall, or sound barrier)
View mbs's profile
mbs
#6 posted 12-24-2014 02:32 AM
Finally finished the clearview installation. With one blast gate open the noise level is 64 db. I’m very satisfied. If you’re interested, I described & put some photos in “My workshop”. The description starts about half way down the page.
