table saw wont cut square
Forum topic by droppedtuning posted 11-27-2014 01:40 AM 1596 views 0 times favorited 9 replies Add to Favorites Watch
View droppedtuning's profile
droppedtuning
31 posts in 2006 days
11-27-2014 01:40 AM
i know this is a old common question but advise please. i have a riigid 3650 table saw i have had for years i bought new. it has always been a good saw but lately i cant get it to cut square. i have put the dial indicator on it from the miter slot to the saw blade and its very true within maybe a thousandth from front of blade i marked with sharpie and rotated to back of the blade. even a brand new blade. i also ran the dial indicator from miter slot to fence in many positions and it is very close. after many cuts on 24×24 panels they are always out of square. 1/8 inch diagonally . the fence has that “factory slop” but it locks down tight. is this common with the factory fences? will a new better fence cure me? any suggestions for a new fence, as i have been out of work for a while and money is a issue. delta t2 maybe or others. thanks for you input good sirs
9 replies so far
View Tooch's profile (online now)
Tooch
1823 posts in 2081 days
#1 posted 11-27-2014 02:32 AM
check for adjustments on the fence. i know on some fences there are set screws that will allow you to adjust the angle to match the blade.
-- "Well, the world needs ditch-diggers too..." - Judge Smails
View Tedstor's profile
Tedstor
1678 posts in 2838 days
#2 posted 11-27-2014 02:53 AM
I have to agree. The fence seems like the culprit here.
Try cutting a piece while the fence is held firmly in-place with a C-clamp (or similar). See if that helps. If so, then you’ll KNOW its the fence.
View AlaskaGuy's profile
AlaskaGuy
4818 posts in 2514 days
#3 posted 11-28-2014 05:45 AM
Check and see if you saw is making parallel cuts. Rip a piece of plywood a foot wide and accurately bothe ends and see if they read exactly the same on each end. If not then the fence, blade or both need attention.
Unless you’re use a miter gage, sled or a sliding table, a table saw doesn’t’ make square cut it just makes parallel cuts. If you start with 2×4 panel that’s not square to start with it’s not going to get square by cutting using the fence alone.
Are you use a good sharp blade?
http://www.woodweb.com/knowledge_base/Cutting_Square_on_the_Table_Saw.html
View Ted's profile
Ted
2874 posts in 2416 days
#4 posted 11-28-2014 06:20 AM
I once resolved the issue with a new, high quality blade. I couldn’t figure out how the saw could be cutting out of square when everything was adjusted perfectly accurate, then somebody suggested the blade might be dull and causing it to veer to one side or the other as I was making the cut. Also, if you’re using a thin-curf blade replace it with a thicker one.
-- You can collect dust or you can make dust. I choose to make it.
View mudflap4869's profile
mudflap4869
1875 posts in 1664 days
#5 posted 11-28-2014 11:33 AM
I am with Ted, a dull blade will ruin your whole day. Check the cut and see if it actually cut or torn wood. A couple of dull teeth is all it takes to veer to that side.
-- Still trying to master kindling making
View Nubsnstubs's profile
Nubsnstubs
1422 posts in 1935 days
#6 posted 11-28-2014 01:11 PM
Unless you re use a miter gage, sled or a sliding table, a table saw doesn t make square cut it just makes parallel cuts. If you start with 2×4 panel that s not square to start with it s not going to get square by cutting using the fence alone.
- AlaskaGuy
Exactly.
Also, after cutting, instead of measuring each end, flip you piece end for end and check the gap you have. If there is no space between wood, fence and blade, your problem lies with the wood supplier selling you shop grade sheet goods and not letting you know that important piece of information. ............ Jerry (in Tucson)
View Larry Wilson's profile
Larry Wilson
25 posts in 1981 days
#7 posted 11-28-2014 05:00 PM
Not sure if this might help but on my Ridgid R4512 I find that I need to push the fence forward to get it square. I can actually see the fence swing over a little bit when I do that. Hope that helps you.
-- Shoot pool, not people
View rantingrich's profile
rantingrich
372 posts in 1550 days
#8 posted 11-28-2014 06:11 PM
The very first and most significant measurement in any table saw is the blade square with the miter slot. If you can,t make that happen get a new saw.
Yes everyone on here with a R4512 feels your pain!
-- Rich
rantingrich
#9 posted 11-28-2014 06:15 PM
Cutting a perfectly square panel is NOT as easy as one would think and it seems every little variant is there to be against you..
My ridgid TS will cut straight rips but it seems to not touch snuggly against the rip fence twards the outfeed. Cant seem to figure that one out
-- Rich
