worn-out bar clamps
« back to Hand Tools forum
Forum topic by BigNate78 posted 11-26-2014 01:02 AM 1470 views 0 times favorited 14 replies Add to Favorites Watch
View BigNate78's profile
BigNate78
10 posts in 1529 days
11-26-2014 01:02 AM
Any one know of a way of getting old bar clamps to re-grab the bar? mine seem to be slipping as i tighten them…
14 replies so far
View buildingmonkey's profile
buildingmonkey
242 posts in 1785 days
#1 posted 11-26-2014 01:11 AM
I have some old Sears pipe clamps I have to hold onto the clamp as I tighten them. Think I’ll give them to my SIL.
-- Jim from Kansas
View distrbd's profile
distrbd
2252 posts in 2684 days
#2 posted 11-26-2014 01:32 AM
The cheaper type of pipe clamps have ratcheting gears with springs to push them tight against the pipe ,as they get old the gears wear out and don’t grab the pipe as they should,I find switching to black pipes will help but over all I would invest in the better clamps like bessy/pony which have clutch plates ,they perform better and are more reliable.
-- Ken from Ontario, Canada
View Mark Davisson's profile
Mark Davisson
597 posts in 3555 days
#3 posted 11-26-2014 02:05 AM
With mine, I have found that “roughing up” the bar, itself, helps. I’ll take a file to mine about once a year – but it doesn’t take much.
-- I'm selfless because it feels so good!
View altendky's profile
altendky
169 posts in 2448 days
#4 posted 11-26-2014 11:33 AM
For either the ‘ratcheting gear’ or ‘clutch plate’ type I would expect that what has changed is that the sharp edges that actually grip the pipe or bar have dulled over the years. I would suggest sharpening them up with a file and see if it helps and how long. Note that this is not written from experience in fixing this issue, just sharing some thoughts.
View MrRon's profile
MrRon
5264 posts in 3481 days
#5 posted 11-26-2014 07:41 PM
Try one of these re-threading files on the bar of the clamp. You just take a few strokes to put a thread like impression on the bar edge. I assume you are talking about the rectangular bar type clamps; not the pipe type. http://www.wttool.com/index/page/product/product_id/38062
BigNate78
#6 posted 11-27-2014 05:26 AM
I’m talking f-bar clamps….and the screw part grabs…seems the clutch plate keeps sliding as I tighten it..or try to I should say…The few of the jorgensen clamps i have don ‘t have any ridges in the bar and they are the best ones….the old ones…the next best are the brand new jorgensen’s, then the cheap tool shop brand I just got a few months ago…then there is the dreaded grey f-bar clamps from menards…..the no-name ones….those are taking craps on me left and right…..where do I turn for good clamps? Do i bite the bullet and by a set of bessy’s or a $400 set of jorgensens? Or do I just make a bunch? Maybe I’ll just make a bunch instead of wasting money.
View Don W's profile
Don W
19045 posts in 2805 days
#7 posted 11-27-2014 12:03 PM
I’ve found black pipe works better than galvanized.
View rantingrich's profile
rantingrich
372 posts in 1583 days
#8 posted 11-27-2014 12:13 PM
Black pipe has a coating of what is referred to as “JAPAN BLACK” its a tar like coating. I used laquar thinner and course steel wool to scrub it off. I do this before I turn them into bar clamps. Not only does the coating act as a lubricant and lets the clamp slide, it also get on your project.
I know this won’t do anything for worn out old pipe but just saying
-- Rich
View REO's profile
REO
929 posts in 2312 days
#9 posted 11-27-2014 02:15 PM
not sure what type of bar clamp you have. still thinking possibly pipe clamp but either way if you can slide the moveable portion off and flip the locking plate or plates over they will grip again. you will be working on a fresh new edge. not all will be conducive to this.
distrbd
#10 posted 11-27-2014 04:44 PM
Bignate,all of us got it wrong it seems,if you are talking about F clamps with clutch plates,the plates most likely have worn out,see if you can remove the whole screw side from the bar and file the plates a bit at a time,try and see if grabs better,if not,do a bit more.cheap clamps have low grade plates and wear out sooner than they should.
117417 posts in 3815 days
#11 posted 11-27-2014 05:15 PM
I agree galvanized pipe tends to chips and lets the clamps slip after a time. I’ve never found that clamps slip or a need to remove the black coating off of my pipe clamps in close to 30 years of use.
View upchuck's profile
upchuck
540 posts in 1903 days
#12 posted 11-29-2014 02:14 AM
BigNate 78-
If we are talking about standard “f” clamps with clutch plates…?
I think that the clutch plates are what keeps the sliding head from sliding when there is pressure applied. I’ve heard that flipping the clutch plates over will give a fresh edge to the plates where they rub/pinch against the bar of the clamp. I’d try that first. Second, I’d try to roughen up the edges of the bar with sandpaper.
Good Luck
chuck
BigNate78
#13 posted 11-29-2014 05:48 AM
Thanks for all the input folks…I’ll give all advice given a fair shake…
View matador8's profile
matador8
27 posts in 2054 days
#14 posted 11-29-2014 08:51 AM
Hi BigNate,
What I did with my bar clamps to make them re-grab is I got the hacksaw and cut groves right along the bar.
But I also sharpen up the teeth on the lock down so it grabs. It works great now. I hope that helps.
Cheers Graham.
