Delta Mortising Kit for the drill press
Forum topic by Joe posted 287 days ago 959 views 0 times favorited 11 replies Add to Favorites Watch
View Joe's profile
Joe
101 posts in 292 days
287 days ago
Anyone use or have one that would like to opine on. I am thinking on getting one and seen mixed reviews on Amazon. Don’t really want to spend the money on a dedicated mortise machine but don’t want to buy something that wont work well either.
-- Senior Chief
View CaptnA's profile
CaptnA
114 posts in 712 days
287 days ago
From what I’ve seen the reviews are mixed based on what people are comparing them to. Beats the heck out of a chisel and mallet but far cry from designated mortising machine.
One of my friends likes his. The other one loved his – until he tried then bought a mortising machine.
Having access to both, I prefer taking my pieces to the dedicated machine over borrowing the kit to fit my DP.
-- CaptnA - "When someone hurts you, write it in the sand so the winds of forgiveness will scatter the memory... "
View ChicoWoodnut's profile
ChicoWoodnut
895 posts in 714 days
287 days ago
They work if you don’t mind frustration. They are very difficult to set up. Most light duty drill presses aren’t designed to produce the force necessary for the tool.
I had one, gave it away and bought a dedicated machine. Every project I make uses mortises. I think it was a good investment.
View woodbutcher's profile
woodbutcher
432 posts in 1065 days
287 days ago
Joe,
I have and use quite often the mortising attachment from Delta on a 30yr old Delta floor model drill press. It does take sometime to set up each time I use it, but it works well. If you only intend to use it on occassion, then it works well. I agree with ChicoWoodnut, it does take a bit of force on the handles of the drill press to operate efficiently. You can get excellent results with it. I’ll add also that should a dedicated mortising machine become available at a very attractice price in the near future, I’ll probably own it! While I have not helped your delimna, I suppose. I’ll reiterate, it does it’s intended job and does it well on a proper sized drill press. It’s really not a gimmick! Hope this is of some help.
Sincerely,
Ken McGinnis
-- woodbutcher north carolina
View tooldad's profile
tooldad
456 posts in 614 days
287 days ago
Agree with most everyone. Have one myself, works, but a lot of setup required. Once you get used to using M&T then you will find yourself wanting either to spend money to get a second DP or a dedicated machine. I found a dedicated machine on CL for $150. Keep searching. Otherwise you will spend money on kit now, then a machine later. good luck
View Patrick Jaromin's profile
Patrick Jaromin
285 posts in 731 days
287 days ago
Ditto tooldad…save your pennies for a used dedicated machine on CL. I’ve got one I’ve used exactly once. By the time I had it set up, I could have routed and hand squared up the mortises…which is what I’m back to.
-- Patrick, Chicago, IL http://www.TenonAndSpline.com/blog
View Sawdust2's profile
Sawdust2
1188 posts in 987 days
287 days ago
I have one made by AMT.
Send me $10 for my troubles in packing it up and the postage and you can have mine.
Probably weighs 10 lbs.
View Mike's profile
Mike
268 posts in 516 days
287 days ago
I got one for 10 bucks on Ebay brand new. It works, set up is a pain. If you do not do a lot of mortises then they are a cheap alternative. Especially for 10 bucks.
If you are going to do a lot then get the machine.
-- Measure once cut twice....oh wait....ooops.
View Joe's profile
Joe
286 days ago
Thanks for all the responses and the offerings. I was drinking some java with the Admiral (wife) this morning, and she asked how the table was coming along. I told her about my dilemma, and she said well if you need one go ahead and get a dedicated mortiser :)
I see Woodcraft has a Steel City bench top on sale for $270. Now I need to go and do some research to find the best bang for the buck.
-- Senior Chief
View pitchnsplinters's profile
pitchnsplinters
252 posts in 337 days
286 days ago
Powermatic has a nice benchtop. If you do a Craigslist search you will find plenty of Jet benchtop mortisers, not sure what that means but you can find them cheap.
-- Just 'cause a cat has kittens in the oven, it don't make 'em biscuits.
ChicoWoodnut
285 days ago
Dude!
That rocks.
Now lets see some mortises (morti?)
Hmmmm
Beginningwoodworker
4231 posts in 572 days
282 days ago
I have that mortising kit for my drill press! It works fine!
-- CJIII Future cabinetmaker
