toy makers
Forum topic by daddywoofdawg posted 11-24-2014 05:27 PM 968 views 0 times favorited 11 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1541 days
11-24-2014 05:27 PM
what power tools do you use when making small 5” down parts.my 10” miter saw,table saw (if I had one),and other big power tools seem more dangerous when cutting small parts.
11 replies so far
View CM02WS6's profile
CM02WS6
61 posts in 1308 days
#1 posted 11-24-2014 06:24 PM
Table saw with crosscut sled works well. Supports the work piece with zero clearance on the bottom and back. My sled is quite large, but I’ve also seen other smaller sled designs that are more catered toward small pieces.
Since you don’t have a table saw, you may want to think about making a support that goes on your miter saw. I’m envisioning an “L” shape that sits on the cutting surface.
daddywoofdawg
#2 posted 11-24-2014 06:46 PM
Since you don t have a table saw, you may want to think about making a support that goes on your miter saw. I m envisioning an “L” shape that sits on the cutting surface.
- CM02WS6
I would like to make one, but don’t see a photo of one that works with a slider.know of any photos of one?
View Clouseau's profile
Clouseau
57 posts in 2999 days
#3 posted 11-24-2014 08:40 PM
I use my bandsaws more all the time because my parts seem to be getting smaller. I keep a 1/2” blade on my 14” and an 1/8 or 3/`6 on my 10”. Use a sled and rip fence on a well tuned bandsaw and you will be much safer and happy with the results.
Dan Coleman
-- Dan Coleman, retired Welding Inspector and past IA Teacher
View Redoak49's profile
Redoak49
3197 posts in 1955 days
#4 posted 11-24-2014 11:20 PM
Personally, I do not like small parts on a miter saw and it just scares me. A good sled on a table saw works. I am starting to make some toys and bought a 10” bandsaw to go along with my 16” Band saw. The big one is great for resaw and other larger cuts but not so great for toys and smaller cuts. Clouseau has it right.
View AandCstyle's profile
AandCstyle
3027 posts in 2223 days
#5 posted 11-25-2014 12:53 AM
I routinely cut small parts with the SCMS, BUT I clamp them securely. I put a scrap the same thickness as the workpiece beyond the saw’s clamp and then run a piece of 3/4” plywood from the scrap to the workpiece (sort of like a bridge) and tighten the clamp down on the ply. There is no way the workpiece can move with this setup. HTH
-- Art
View Sawdust4Blood's profile
Sawdust4Blood
403 posts in 2988 days
#6 posted 11-25-2014 01:01 AM
Bandsaw is my go-to tool for small parts
-- Greg, Severn MD
View LeeinEdmonton's profile
LeeinEdmonton
254 posts in 3547 days
#7 posted 11-25-2014 01:25 AM
I don’t have a TS or a SCMS instead I have a RAS for larger work & use my 14” BS small work parts. For real small parts I use my scroll saw. The latter is not so good because Iam not proficient with a scroll saw & there is no fence
so I end up with “BY GUESS & BY GOLLY” results with it. A well tuned BS with a 3/16” blade does a very good job on small parts.
-- Lee
View bondogaposis's profile
bondogaposis
4683 posts in 2317 days
#8 posted 11-25-2014 01:29 AM
Bandsaw is the safer tool for small parts.
-- Bondo Gaposis
View ElChe's profile
ElChe
630 posts in 1302 days
#9 posted 11-25-2014 02:24 AM
My Gramercy bowsaw. Accurate and safe. For 45 or cross cuts my totally awesome Bad Axe hybrid tenon saw.
View Jim Finn's profile
Jim Finn
2647 posts in 2888 days
#10 posted 11-25-2014 10:25 PM
I mostly use a scroll saw to make toys. Hard to hurt yourself on it also.
-- Website is https://craftingcouple.com/
daddywoofdawg
#11 posted 11-26-2014 02:55 PM
sounds like a BS is on the christmas list. Any blk fri deals?
