Understanding How to Use Air Dried Jatoba
Forum topic by CharlesA posted 11-23-2014 09:54 PM 1168 views 0 times favorited 15 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3319 posts in 1792 days
11-23-2014 09:54 PM
Topic tags/keywords: question jatoba milling
A friend offered me a deal on three Brazilian Cherry boards, 9’x15”x1”. I’ve read up a bit and it is supposed to be hard as heck, but pretty easy to glue up and finish. I’ve seen furniture made with it, and I really like the look.
However, now that I have it, I have a few questions. The first is the identification of the wood in general. I know that Jatoba, like all woods, has some variation in color, but I thought it was generally similar to aged black cherry or mahogany, medium to darker brown with a red tint. The boards I have are purple in color. I’ve seen a couple of pics of Jatoba that lean this direction, but this seems pretty far on the purple spectrum.
This wood has been aging for a long time. I have no idea if it was kiln-dried originally, but if it was, my guess it was over a decade ago. It has been sitting under a tarp and roof outside for at least a couple of years. I checked it with my cheapy HF moisture meter, tried it multiple times on each board. 9 was lowest, 11 highest. So let’s just say 10%. How might I best prepare this for use? Mill it, let it sit 24 hours, mill it again and go for it? Let it sit for __ days in my shop before milling it? Something else?
Since the grain is fairly regular and the color very uniform, I’m thinking I’ll eventually cut it into 6” max boards to go on my jointer in milling. No need to keep the wide boards wide.
Any other advice?
15 replies so far
View Dave Rutan's profile
Dave Rutan
1707 posts in 2183 days
#1 posted 11-23-2014 10:00 PM
Wow! That’s a lot of wood! How many zeroes is a brazillion? (Sorry, I’ve been waiting to use that for like 5 years.)
-- Ni faru ion el ligno!
View Tony_S's profile
Tony_S
867 posts in 3078 days
#2 posted 11-24-2014 01:28 AM
I’ve seen Jatoba in every shade of brown you can imagine, some with a red tint when freshly milled, most not. It quite often patinas a red color though. That said….I’ve never seen Jatoba in any shade of purple, aged or otherwise.
Also, if U.S. Import laws are anything like Canadian Import laws(I suspect they are) Your Imported lumber would all have to be kiln dried.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View ElChe's profile
ElChe
630 posts in 1331 days
#3 posted 11-24-2014 01:36 AM
I’ve only used jatoba as an accent piece on a box so my experience is limited. It was really dense and moderately difficult to machine because it burned a bit. A hand plane cleaned up the burning. Careful milling is essential to get a good glue joint. Yellow glue didn’t work for me. I went with a PUR adhesive and for my purpose it worked well. Because it is resiny, I cleaned the joint with acetone and glued it. I also milled it and quickly glued it because my research showed it tends to move a bit especially if it has too much moisture. My recollection is 7-8% moisture content is optimal? Sticker it for a bit in your shop (a couple of weeks depending on the dimensions?) and have at it. It does brown with oxidation but it is beautiful as an accent wood. In wider glue ups I read it moved too much if it had too much moisture. Sharp blades is a must. It dulled my hand plane iron after several passes. Oh, I didn’t have any reaction to working with it but I’ve read some folks can get allergic reaction to natona dust. Good luck.
View summerfi's profile
summerfi
3917 posts in 1682 days
#4 posted 11-24-2014 01:54 AM
Are you sure that isn’t purpleheart? The color sure looks like it. I just finished making a couple of saw handles out of jatoba. The color of the wood I used is a red-orange.
-- Bob, Missoula, MT -- Rocky Mountain Saw Works http://www.rmsaws.com/p/about-us.html
View jap's profile
jap
1251 posts in 2049 days
#5 posted 11-24-2014 01:57 AM
It looks like purpleheart to me.
-- Joel
CharlesA
#6 posted 11-24-2014 01:57 AM
I wondered about Purpleheart—I guess I never pictured it coming in such large boards since I only see it sold in smaller pieces. I also wonder about Brazilian Rosewood: http://www.wood-database.com/lumber-identification/hardwoods/brazilian-rosewood/
I wonder how to figure this out . . .
I wouldn’t care that much except that I don’t want to get into the middle of something and figure out that I’m not milling/gluing/finishing it correctly.
CharlesA
#7 posted 11-24-2014 02:00 AM
Okay—apparently purpleheart trees grow quite large—my ignorance.
CharlesA
#8 posted 11-24-2014 02:12 AM
Gosh. What in the fool am I going to do with 30bf of purpleheart? This is not good news.
summerfi
#9 posted 11-24-2014 02:41 AM
You could always sell some if you don’t have a use for it.
View BikerDad's profile
BikerDad
347 posts in 3596 days
#10 posted 11-24-2014 03:07 AM
- CharlesA
It’s great news. Anything you may have wanted to do with the Jatoba you can do with Purpleheart. They are similar in working characteristics, but there are no complications with gluing the purpleheart. Purpleheart will eventually go brown, but it takes years and some serious UV to do it under finish.
Purpleheart and Maple is a fantastic combination.
-- I'm happier than a tornado in a trailer park! Grace & Peace.
CharlesA
#11 posted 11-27-2014 05:41 PM
Solved my problem. I looked up purpleheart furniture, and I don’t like the look of it in large quantities. Put it on CL, and I sold 3/4 of it for what I paid for it. I have 5bf or so to use on picture frames,etc., and now I can buy some wood I like for furniture.
View bobro's profile
bobro
320 posts in 1305 days
#12 posted 11-27-2014 05:56 PM
Woods vary in color. I picked up a couple of boards of pau ferro (morado) industrial flooring leftovers for peanuts- it is a dark rich purple finer than any purpleheart I’ve ever seen, and that’s the color it oxidizes to. Freshly sawn it looks like your regular honey kind of color pau ferro. Maybe jatoba has such variation, too.
By the way, purpleheart ages to various very noble and luxurious shades of brown, honey maroon, and so on, not garish purple. This bugs people who prefer the straightforward purple but I prefer the aged colors.
-- Lao Ma: You are so full of anger and hatred. Xena: Everybody's gotta be full of something.
CharlesA
#13 posted 11-27-2014 06:08 PM
Could be, but it am making a coat rack for,the living room, and I don’t want it to be purple. I like the dark tone of 10’year old purpleheart, but I’m not that patient.
bobro
#14 posted 11-27-2014 06:11 PM
Yeah I get what you’re saying. Well somebody scored some wood they love, and you have some left for small stuff, so it’s win all the way around!
CharlesA
#15 posted 11-27-2014 07:26 PM
Yup. I’m happy. He’s going to use it for the transom on a boat. Good all around c
