Some advice please
Forum topic by jeffswildwood posted 11-23-2014 04:08 PM 1003 views 0 times favorited 4 replies Add to Favorites Watch
View jeffswildwood's profile
jeffswildwood
3187 posts in 1975 days
11-23-2014 04:08 PM
Topic tags/keywords: question
http://lumberjocks.com/projects/107382 Please see this box before reading!
I have had a lot of success with my latest box style and just completed version 3.0 for a customer. (Posted soon) by adding a drawer. My wife has thrilled over each one and I want to make her one for Christmas. This will be version 4.0 and I need some advice for the lid. The other three were made of poplar sides with pine corners and legs. Lots of material available. I have just enough birds eye maple at 1/2 inch from the box swap for the sides and walnut for the corners and legs. Not enough BEM for the lid at 1/2 inch as used in prior design. I do have a piece of birds eye at 1/4 inch that would fit the bill but I need a new design if a lid is to work with available material. I have toyed with a few ideas.
1) Rabbet the top of the box and cut the 1/4 BEM to be recessed into the lid as a assembled box then cut off the top with TS.
2) Cut a groove about 1/4 inch down and do the same as above leaving a lowered portion of BEM.
3) Cut some walnut at 3/4 inch wide, 1/2 inch thick and make a walnut border around the top with the BEM inside the border.
With this choice of woods it should be a beautiful box when done but with limited material I can’t afford trial and error. Any suggestions or cool ideas would really be appreciated! Just having a 1/4 inch top just won’t work.
Sorry for adding the link above but I could not get a picture to post here.
-- We all make mistakes, the trick is to fix it in a way that says "I meant to do that".
View jumbojack's profile
jumbojack
1676 posts in 2621 days
#1 posted 11-23-2014 04:28 PM
I would go with option 2. While I don’t t think you would have to concern yourself with the BEM moving it is a possibility so option 3 is out. Option 1 is ok but again movement and I think with all of your angles there will be a gap somewhere. With option 2 you can have a little wiggle room. Further 1/4” is a bit too much ‘edge’ 3/16 or a shade less will be good, unless you chamber that inside edge. I have built many boxes with the dado and they come out very nice
Love your box design, you are doing quality work.
View ElChe's profile
ElChe
630 posts in 1334 days
#2 posted 11-23-2014 04:35 PM
Hopefully this is the box. Love the design.
I like the simplicity of the lid. Hmm. I like the idea of using the BEM as an inlay into the walnut. Here is a humidor with inlay of BEM.
My suggestion would be to use a router inlay template to inlay the BEM into a solid walnut lid?
jeffswildwood
#3 posted 11-23-2014 05:14 PM
Jumbo, I like option 2 also. Agreed, 1/4 may be a bit much, instead of campher use roundover, wife likes rounded edges.
ElChe, thanks for posting my box, you know, I like that recessed look. I’m feeling that quite a bit right now.
jeffswildwood
#4 posted 11-30-2014 12:33 AM
I really wanted to go with ElChe method but discovered my walnut stock is 1/4 inch to narrow. I wanted the dark border on the top so….I’m going to give option three a try. I think if I leave a little wiggle room in this I may be OK considering the size.
