Scollaped edges off Jointer
Forum topic by unisaw posted 11-22-2014 02:53 PM 1176 views 0 times favorited 6 replies Add to Favorites Watch
View unisaw's profile
unisaw
92 posts in 4132 days
11-22-2014 02:53 PM
I am trying to edge joint boards with my Grizzly 6” jointer. I installed Dispoz A Blade knives two years ago and they seem to be seated properly. They have had very little use. The outfeed table appears to be set at the height of the blades and won’t go any higher. What should I be looking for to get a smooth cut? The effect now is waves that are 1/4” apart along the entire edge.
View BobLang's profile
BobLang
155 posts in 3399 days
#1 posted 11-22-2014 02:55 PM
One of your knives is higher than the others.
-- Bob Lang, https://readwatchdo.com
View ElChe's profile
ElChe
630 posts in 1336 days
#2 posted 11-22-2014 03:36 PM
Try moving fence and joint using a different area of the blades to see if one of the blades is high in one corner or across its entire length. Also try un plugging the jointer. Then rotate each blade to its high spot and slide a straight edge board from out feed table into cutter and see if it hits one of the blades. That would be the high one. Good luck.
View AlaskaGuy's profile (online now)
AlaskaGuy
4136 posts in 2308 days
#3 posted 11-23-2014 05:15 AM
Probably the bes way to check to see if one knife is higher than the others is with a dial indicator.
Because the jointer knives travel in an arc, each cut creates a scallop. The ridges between the overlapping scallops are known as mill marks. These can ruin the appearance of your project. To keep mill marks to a minimum, feed the work slowly and use a shallow depth of cut.
4986 posts in 2492 days
#4 posted 11-23-2014 01:50 PM
- AlaskaGuy
What he said….the slow feed rate eliminates it.
unisaw
#5 posted 11-25-2014 04:41 PM
Thanks all. There was a high blade and I replaced it. The results were much better. I’ll replace the others next and pick up a dial indicator. BTW, the owner of Dispoz a Blade called me back first thing Monday morning and suggested the same thing – check the blades. The good news is that this forced me to dust off my jointer plane and experiment with that. It needs a tune-up. The journey back to hand tools has begun.
AlaskaGuy
#6 posted 11-25-2014 06:53 PM
Thanks all. There was a high blade and I replaced it. The results were much better. I ll replace the others next and pick up a dial indicator. BTW, the owner of Dispoz a Blade called me back first thing Monday morning and suggested the same thing – check the blades. The good news is that this forced me to dust off my jointer plane and experiment with that. It needs a tune-up. The journey back to hand tools has begun.
- unisaw
At 95 dollars it’s the cheapest one you can get but I like this setup for jointer knives.
http://www.oneway.ca/workshop/multi-gauge.htm
