Bench Holes?
Forum topic by rantingrich posted 11-22-2014 02:31 PM 1047 views 0 times favorited 10 replies Add to Favorites Watch
View rantingrich's profile
rantingrich
372 posts in 1221 days
11-22-2014 02:31 PM
I am curious? I am planning on making my own woodworkers bench. Of course with holes drilled in it for bench dogs.. Does one drill all the way through the TOP? or not
-- Rich
10 replies so far
View bondogaposis's profile
bondogaposis
4541 posts in 2227 days
#1 posted 11-22-2014 02:38 PM
Yes, absolutely, drill all the way through.
-- Bondo Gaposis
Rick Dennington
5659 posts in 3070 days
#2 posted 11-22-2014 02:56 PM
It’s up to you….You can always drill half way through, and have “stub dogs”....!!!!!!!!!!!!!!!
-- " Don't pet the sweaty things, and don't sweat the petty things."
View ElChe's profile
ElChe
630 posts in 1212 days
#3 posted 11-22-2014 04:02 PM
If you drill all the way through the sawdust will clear the hole and you can use holdfasts etc.
View Redoak49's profile
Redoak49
3017 posts in 1864 days
#4 posted 11-22-2014 04:45 PM
I drilled 3/4” holes all the way through. I used an Irwin solid center auger bit. I drilled a solid block of wood about 2.5” thick on my drill press first. I used the block to keep my drill at a right angle to drill all the holes. On some of the holes, I fastened a block of wood on the underside of the bench that was tapped for a 3/4” wooden thread. This allows me to “bolt” things to the work bench with a wood threaded rod and wooden nuts. It has really worked well for me and better than the hold downs that you pound into the hole.
View TheDane's profile
TheDane
5350 posts in 3539 days
#5 posted 11-22-2014 04:49 PM
By all means drill all of the way through … otherwise, you’ll have deep pockets of sawdust/chips that are a PITA to clean out. I drilled mine (6” on centers), starting with a 3/4” Forstner bit for the first half inch or so, then chucked up an Irwin 3/4” auger bit. I clamped a piece of scrap plywood across the bottom to minimize blowout.
Rick Dennington
#6 posted 11-22-2014 05:10 PM
AAH….You guys let the cat out of the bag….I was japeing Rich…...Hadn’t had enough coffee yet….By all means you want drill dog holes all the way through the top….I built a jig to do mine…
4830 posts in 2369 days
#7 posted 11-22-2014 05:48 PM
Yep, all the way through. But look at this way, if you want to try the “stub dogs” you can always go back later and do what everyone said.
TheDane
#8 posted 11-22-2014 07:16 PM
Something I have been meaning to do (the last 5 years!) is chuck a 1/4” roundover bit in a router and ‘ease’ the holes in my benchtop. I have a couple that have chipped out a bit … maybe rounding them over would prevent some of this.
Smitty_Cabinetshop
14973 posts in 2494 days
#9 posted 11-22-2014 07:17 PM
^ Dane, yes, that helps a lot to prevent chipping.
View Tedstor's profile
Tedstor
1643 posts in 2508 days
#10 posted 11-23-2014 12:19 AM
I have an school woodshop bench with steel lockers for the base. The top only over hangs the lockers by a few inches, thus I wasn’t able to drill dog holes all the way through the top. Yes, this sucks. I have to occasionally clean the holes out with a shopvac in order to use the dogs.
