DELTA 14" BANDSAW MODEL 28-275
Forum topic by FreddieM posted 11-21-2014 11:40 PM 1449 views 0 times favorited 4 replies Add to Favorites Watch
View FreddieM's profile
FreddieM
2 posts in 2353 days
11-21-2014 11:40 PM
My delta 14” bandsaw model 28275 seems to be having a problem with the lower bearing. Is jamming up and won’t budge! I have to force it backwards to get it to move. Won’t start turning on its own. Anyone know how hard it is to change the lower bearing and should I replace the shaft too?
View Chris208's profile
Chris208
239 posts in 2269 days
#1 posted 11-21-2014 11:43 PM
Are you talking about the lower wheel bearings, or thrust bearing?
View ElChe's profile
ElChe
630 posts in 1335 days
#2 posted 11-21-2014 11:48 PM
Thelower thrust bearing that the blade hits when you cut wood? Or the lower wheel bearing? The thrust hearing comes off easily and you shouldn’t need to replace any part of the blade guide assembly. The wheel has two bearings and they are slightly less easy to replace but very doable. You can get both way cheaper from a bearing shop than from Delta.
View MrUnix's profile
MrUnix
6714 posts in 2198 days
#3 posted 11-21-2014 11:57 PM
Lower wheel bearings are super easy to replace.. upper wheel bearings are actually a bit harder. Thrust bearings are a snap. Hopefully you didn’t damage the shaft.. but if left like that for any length of time, it will be.
ElChe
#4 posted 11-22-2014 01:31 AM
This link has a PDF at bottom that shows how to remove thrust bearings.
http://www.spaceageceramicguideblocks.com/Installation.html
