Wax problem
Forum topic by Rich L. posted 11-21-2014 06:34 PM 866 views 0 times favorited 6 replies Add to Favorites Watch
View Rich L.'s profile
Rich L.
30 posts in 2244 days
11-21-2014 06:34 PM
Hello all,
I made some small boxes recently. I finished them with Danish oil and wax. The wax on the box bodies looks OK; but the lid panels look streaky! I tried buffing by hand and with a buffing wheel but the still look crummy. I tried paste wax, furniture wax and bees wax. No luck.
Any ideas or recipes that might help me out would be appreciated.
I’ve added a couple photos. They don’t show much but they might help
Thanks
-- Rich, Southern CA
View mahdee's profile
mahdee
3873 posts in 1734 days
#1 posted 11-21-2014 06:39 PM
If it is only the lid panel and they are made with veneer. Then perhaps due to the veneer being so thin and the glue creating a barrier, the Danish Oil did’t completely didn’t dry on those surfaces. Other than that, I have no clue. Looking closer at the tops, they don’t look like veneer.
-- earthartandfoods.com
View waho6o9's profile
waho6o9
8165 posts in 2544 days
#2 posted 11-21-2014 06:50 PM
I would use a card scraper and clean up the streaks
and just use wax.
Great looking boxes BTW.
Good luck now.
View jmartel's profile (online now)
jmartel
7807 posts in 2117 days
#3 posted 11-21-2014 06:52 PM
What glue did you use for the veneer? It likely seeped through a bit and could be interfering with the finish.
Rich L.
#4 posted 11-21-2014 07:14 PM
No veneer. They are all solid wood.
View OSU55's profile
OSU55
1632 posts in 1956 days
#5 posted 11-21-2014 08:47 PM
My experience suggests 2 possibilities: 1) Oil finish has streaks/uneven sheen and the wax isn’t evening it out, or 2) too much wax. Remove the wax with mineral spirits and check for even sheen of the topcoat. Sand or scrape to even out the sheen, and you may need to add another oil coat. If the top coat sheen is even, then you probably had wax build up in spots. Once the wax is dry, it can be difficult to buff out.
Rich L.
#6 posted 11-22-2014 06:58 AM
Thanks for the responses. Think I’ll the suggestion of OSU55 and strip it. I did keep adding coats of was in hopes of getting a better result.
Thanks again all.
