| Forum topic by jim1942 | posted 287 days ago | 442 views | 0 times favorited | 10 replies | ![]() |
287 days ago |
I am refinishing a buffet top. It’s 20” x 60” wood species unsure but appears to be medium to soft. -- jim1942 |
287 days ago |
Which brand of finishing products are you using? -- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower." |
287 days ago |
Yes, first question would be what brand oil..I like general finishes. But it’s probably that wax. I recently did a little sample board on some nice walnut, and three coats of arm-r-seal made it shine like crazy, beautiful! Then when I hit it with a little wax, it dulled the extreme gloss the wiping varnish gave me. It was still nice, still more gloss than when I had started, but it wasn’t anyplace near the great shine without the wax. -- "That which has in itself the greatest use, possesses the greatest beauty." - Unknown Shaker |
287 days ago |
Might try wiping the wax off with a rag moistened with mineral spirits and putting on a poly or alykd varnish that has more resin solids than straight or thinned tung oil. You might get better moisture and heat protection as well. Behlens Rockhard, Waterlox original, Pratt and Lambert #38 Alykd and a host of waterborne products come to mind. -- "Bordnerizing" perfectly good lumber for over a decade. |
287 days ago |
For sure there are issues between the stain and the tung oil. Tung oil at normal temperatures dry fast, and its easy to polish the final wax coat. I use MYLANDS wax polish and I have use Butcher’s with excellent results in both cases. -- Francisco Luna, San Francisco Bay Area. |
287 days ago |
I found that one has to apply many coats to get a decent gloss. I ended up waiting a few days until my last coat cured completely and then went over the top w/0000 steel wool. Then, I applied a copy of coats of gloss polyurethane…....results were excellent and with better resistance to wear and water. -- scmichael |
287 days ago |
Thanks to all. -- jim1942 |
287 days ago |
I’ve found that tung oil finishes need to FULLY cure before you use a paste wax on them. I ruined a few projects before I read that the solvents used in the wax can and will eat into uncured finishes. Tung oil should set at least 72 hours ( in ideal warm not too damp shop) to fully cure. Also the get a high gloss from any paste wax you need several to many coats to really shine. A buffer will bring up the shine much more than you could get by hand polishing——unless you really like rubbing out the wax! -- http://www.grandprairiewoodworks.com http://www.etsy.com/shop.php?user_id=6453794 |
287 days ago |
jim1942: Miniwax doesn’t sell tung oil. They sell a product called “Tung Oil Finish”, which contains only a tiny amount of tung oil that has been chemically modified. Note: There are currently no regulations in the USA for finishing products called “Tung Oil Finish”. Now—How to solve your problem. One way is to strip off the wax with solvent and elbow grease, then start over. For a top finish, consider any good varnish or polyurethane, including the Miniwax product with adequate coats to build a nice finish. Again, follow the instructions. Finally, it is always best to experiment on a piece of the actual wood you will be using. -- Randy, Rustic Artisan, a family tradition. (No PM's - auto-deleted.) - "I am a seeker, not a follower." |
287 days ago |
If you have any scrap and since you aren’t sure of the species I’d try wiping the wood with denatured alcohol and when dried well retry your finish. I had a similar issue once and the DNA helped. -- CaptnA - "When someone hurts you, write it in the sand so the winds of forgiveness will scatter the memory... " |
285 days ago |
Again Thanks to all. -- jim1942 |
| Forum | Topics |
Woodworking Skill Share
2931 |
3962 |
257 |
955 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
