Kickback
Forum topic by Jose posted 11-18-2014 04:49 PM 1289 views 0 times favorited 12 replies Add to Favorites Watch
View Jose's profile
Jose
102 posts in 1677 days
11-18-2014 04:49 PM
Anyone owns a Ridgid R4510 table saw? If you do I need your help/advice. I experienced kickback with this TS 3 times already and to be honest that is more dangerous than I thought. I have a nasty bruise on my upper leg now. Anyways, the reason this happened I believe is that somehow either the fence or the blade are not perfectly squared to each other (sounds like common sense, right, duh!. However, I keep measuring the fence to the blade and miter slots and all seemed correct both front and back. Very strange! Even the riving knife seems to be straight and also when I place it on a flat surface.
I used a zero clearance insert to make the cuts so I had to remove the ZCI; everything was ok with the starting cuts except when passing the wood through the back when I felt it binding to the fence and blade. The blade is at 90 degrees (at least the digital gauge reads 89.9 degrees at times), but the boards bind to the back making it hard to push through so I have to shut off the saw so I can remove the board. Otherwise the cuts are not square because the back of the blade cuts 1/16” or maybe less to the board.
So, if you have the same problem, what adjustments you made to the fence to rectify this problem?
-- Jose
12 replies so far
View mahdee's profile
mahdee
3888 posts in 1791 days
#1 posted 11-18-2014 05:41 PM
Are you making a cross cut? if so, you should not use the fence.
-- earthartandfoods.com
View jdh122's profile
jdh122
1018 posts in 2841 days
#2 posted 11-18-2014 05:46 PM
Any chance you have a thin-kerf blade and a regular-kerf riving knife? Doesn’t sound like it in your description (it wouldn’t bind on the blade but rather on the rk if this was the case)...
-- Jeremy, in the Acadian forests
View pintodeluxe's profile
pintodeluxe
5702 posts in 2837 days
#3 posted 11-18-2014 05:53 PM
To add to Mr. Jinx’s comment… you can use a crosscut sled to crosscut large boards and planks.
The Ridgid TS has a riving knife?
Is the edge against the fence straight and true? If not, joint it flat before ripping to width. If you don’t have a jointer, you can use a taper / ripping jig on the TS.
And what do you mean you had to remove the ZCI? Why? Sorry, I just didn’t understand that part of your post.
View dbray45's profile
dbray45
3320 posts in 2800 days
#4 posted 11-18-2014 06:14 PM
if you are ripping along the fence, have the fence go slightly away from the blade in the back. if you are cross cutting without a sled (using a miter fence, the only way to do this safely is to put a 1” spacer clamped to the rip fence and should only be long enough to set the space.
When the piece that you are cutting touches the blade, you should have 1” of free space between the work and the rip fence. At this point, you can push the piece through the blade using the miter fence. The best thing to do is make a simple sled – keeps your fingers away from the blade.
If you are ripping long irregular wood, put a straight piece that is longer than the piece you are cutting against the fence, this will allow you to use the entire edge of the piece you are ripping along this extended fence.
If it starts to bind, STOP and hold where you are and shut off the saw – wait for it to stop before you remove the wood from the blade. Trying to remove the wood will bind it and kick it – you know this already!
-- David in Damascus, MD
View Jose's profile
Jose
#5 posted 11-18-2014 06:18 PM
All the cuts I made were rip cuts. The kerf of the blade is regular kerf and the table saw has a riving knife.
pintodeluxe, what I meant to say was that because of the kickback I had to remove the zero clearance insert and put in the stock throat plate with the riving knife so I could rip cut safely.
-- Jose
dbray45
#6 posted 11-18-2014 06:24 PM
Your rip fence is not adjusted correctly, your blade is not true (could be bent), or you could have dirt against the blade in the spindle – remove it and clean the spindle and blade, you may have some debris in there.
If you kicked a large enough piece of wood, you could have bent something.
View Jose's profile
Jose
#7 posted 11-18-2014 06:25 PM
Thanks dbray45, that is exactly what I had to do, shut off the saw before removing the board. I just learned that I can make adjustments to the fence by loosening or tightening the attachment pins that run along the rail of the saw.
-- Jose
View Jose's profile
Jose
#8 posted 11-18-2014 06:27 PM
That could be true. I have to check all these things you guys suggested. It could be most likely that the blade bent as dbray45 says. I hope is just that and nothing major in the saw itself.
-- Jose
View jmartel's profile
jmartel
7953 posts in 2174 days
#9 posted 11-18-2014 06:38 PM
Cut your zero clearance insert to accommodate the riving knife. I wouldn’t ever take the riving knife off. Also your fence may need adjustment.
View Yonak's profile
Yonak
986 posts in 1545 days
#10 posted 11-18-2014 06:51 PM
You may check to be sure your wood isn’t bending after you push it through the first half of the blade. If there’s tension in the wood that is released during the cut the wood could be bending and pressing against the blade.
mahdee
#11 posted 11-19-2014 01:01 AM
It would be great if you could video of what is happening as you make your cut.
View WOODIE1's profile
WOODIE1
117 posts in 2303 days
#12 posted 12-01-2014 12:23 AM
Spend an hour or so setting the saw up and making sure all is square. The obvious is to set the fence an inch or so from the blade and measure from the rear of the blade to fence and then front of blade to fence. Most likely the rear is closer. If you have a splitter of some sort use a straight edge on both side of the blade to see if it hits the splitter.
Anything that causes a bind or push on the wood can close up your cut creating kick back. Be careful and do some measuring.
