Small dips at the end of a routed edge
« back to Joinery forum
Forum topic by Russianspy posted 11-18-2014 03:02 PM 1061 views 0 times favorited 6 replies Add to Favorites Watch
View Russianspy's profile
Russianspy
3 posts in 1191 days
11-18-2014 03:02 PM
Topic tags/keywords: router table edges imperfections
At the end of each pass on my router table I am getting small imperfections where it looks like the bit is cutting a little (1/32 – 1/16 in) more than the rest of the pass. I’ve tried moving the fence in and out, but I just can’t get them to go away. I have using feather boards in both the horizontal and vertical directions. Thanks for any help, this is my first router table project.
View timbertailor's profile
timbertailor
1594 posts in 1329 days
#1 posted 11-18-2014 03:12 PM
Do you have a picture of your set up?
If I had to take a wild guess, you have a two part fence and they are not in line with one another.
Russianspy
#2 posted 11-18-2014 03:26 PM
It’s a Bosch Table router ( http://www.amazon.com/Bosch-RA1181-Benchtop-Router-Table/dp/B000H12DQ6 ), which does have a 2 part fence. Any advice on how to align the 2 sides? The 2 pieces of MDF bolt right to aluminum fence, but there isn’t a way to adjust them in or out.
View muleskinner's profile
muleskinner
896 posts in 2342 days
#3 posted 11-18-2014 04:12 PM
Dollars to donuts you have a split fence, right? I had the same problem with the split fence on my Ryobi table. Now, for critical edge routing I clamp on an auxiliary solid fence. Solves the problem.
-- Visualize whirled peas
View levan's profile
levan
472 posts in 2884 days
#4 posted 11-18-2014 04:34 PM
You could clamp on an out board fence if your boards are straight and equal widths. With this you are riding off the opposite edge.
You can also adjust your existing fence by shimming behind them, a lot of the time just paper shims are enough. Sounds like your boards may be dropping in the thickness of the cut when coming off the in feed fence. Out feed fence should be flush with cutter. Infeed fence should set in depth of cut.
Best wishes
Lynn
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
Russianspy
#5 posted 11-24-2014 01:20 AM
I tried the paper shims and they did the trick, thanks so much for all your help!
timbertailor
#6 posted 11-24-2014 05:31 AM
- Russianspy
Glad you got it sorted out.
