1/2" Solid Panel for Box Frame Construction
Forum topic by Nugs posted 11-18-2014 02:07 AM 1271 views 0 times favorited 4 replies Add to Favorites Watch
View Nugs's profile
Nugs
66 posts in 1783 days
11-18-2014 02:07 AM
Hi All,
I mostly enjoy lurking with an occasional post every now and then, but today I have a question. I’m planning on building a nightstand sort of similar to the one pictured. Is it a bad idea to glue up 2 or 3 pieces of 1/2” cherry to make a 16” wide panel for the side/top/bottom of the box?? Is gluing up 1/2” that wide just asking for warping trouble? I could use dovetails to help avoid warping or do you think mitres will be fine?
I’ll be resawing the 1/2” pieces from some 9/4 cherry I have. I could also make the sides a bit thicker, but I want to get the most milage out of my wood.
Thanks,
Craig
View timbertailor's profile
timbertailor
1594 posts in 1330 days
#1 posted 11-18-2014 01:58 PM
Most of us do this all the time with a biscuit jointer.
Keeps the surfaces even with one another while gluing.
View CharlesA's profile
CharlesA
3305 posts in 1703 days
#2 posted 11-18-2014 02:24 PM
Brad, you use biscuits on 1/2” material? I thought I’d heard that biscuits were prone to swelling 1/2” thick pieces.
View levan's profile
levan
472 posts in 2885 days
#3 posted 11-18-2014 03:01 PM
Gluing up panel widths is very common. Panels that wide will have a lot of movement. Long term I think the dovetails will hold the joints much better.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View jdh122's profile
jdh122
983 posts in 2723 days
#4 posted 11-18-2014 04:48 PM
Go for it on the glue-up. But regardless of the thickness of the material used I’d be reluctant to make a carcase like that one only with miter joints.
-- Jeremy, in the Acadian forests
