Oops wrong spindle thread!
« back to Woodturning forum
Forum topic by REO posted 11-18-2014 12:53 AM 851 views 0 times favorited 3 replies Add to Favorites Watch
View REO's profile
REO
928 posts in 1981 days
11-18-2014 12:53 AM
I decided to modify my lathe. I wanted to adapt is so that it would be easier to do rosettes and flat work rather than bending over the lathe all the time. I use a duplication system now and wanted the template in the same axis. In order to do this i needed to mount a headstock at 90 degrees to the bed and make a “T” lathe. I found an atlas 6” headstock on ebay for 80.00 and a scroll chuck setup for another 139.00. I thought the spindle would be 1”-8. WRONG! the spindle is 1”-10 kind of an odd thread. I drew up a cross section of both threads and superimposed them on one another. It looks like I still have 80% of the 70% original thread or about 56% thread in contact. So I was thinking of running a 1”-10 tap through the 1”-8 chuck. Better ideas?
3 replies so far
View LeeMills's profile
LeeMills
506 posts in 1208 days
#1 posted 11-18-2014 01:13 AM
What brand chuck do you have? Most of the better ones have inserts instead of direct threaded. I am most familiar with Teknatool (Nova). They have two 8X10 and the Insert C is the R hand. I think you will be better of to return the chuck and swap it for an insert style.
If you scroll down on the link there is a full listing of available inserts.
http://www.teknatool.com/products/Lathe_Accessories/adaptor_page.htm
You can get the Nova G3 for about the same price. If you ever want to move it to a different lathe, maybe one with an 1.25X8 spindle, all you need to do is buy the different insert.
I would think there are at least 4-5 brands that have inserts available in that size.
It may not happen but I think you may be stuck with excessive run out trying to re-thread your chuck.
My second option would be to try and find an adapter to go from the X10 to the X8.
Also I believe the Shopsmith has a 5/8 spindle. If there is enough meat you may be able to drill out and rethread this insert to you 1X10.
http://www.pennstateind.com/store/L5818.html
View Rick_M's profile
Rick_M
11121 posts in 2287 days
#2 posted 11-18-2014 02:19 AM
Oneway sells adapters for pretty much every spindle size there ever was.
-- http://thewoodknack.blogspot.com/
View REO's profile
REO
#3 posted 11-18-2014 03:05 AM
Well, I wanted to stay away from an adapter if I could I thought there was greater oportunity for runout with one of those. this particular chuck came with an insert for a 3/4” thread to 1”-8 and since the thread is already1” it is the correct OD so there is no room for an insert. There is room to bore and thread the inner for 1 1/2-8 like the rest of my lathes I suppose. I had planned on leaving the setup in tact and just moving it back from the bed to use the lathe conventionally. Thanks for the input ! I’ll have to muse over it a bit.
