squeeze out on plywood
Forum topic by trevorlamont posted 11-17-2014 08:47 PM 919 views 0 times favorited 7 replies Add to Favorites Watch
View trevorlamont's profile
trevorlamont
15 posts in 1958 days
11-17-2014 08:47 PM
Hey guys! In your experience, what has been the best way to remove dried glue on plywood? I haven’t tried anything yet. Its really a pretty thin layer that squeezed out, i just dont want to damage the veneer.
Thanks in advance guys!
7 replies so far
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2068 days
#1 posted 11-17-2014 10:24 PM
What kind of glue? PVA (careful application of heat, or sanding) CA ( careful sanding) Urethane (soak in mineral spirits) Hide glue (application of heat) . Careful sanding or scraping with very sharp card can take care of most.
-- Who is John Galt?
trevorlamont
#2 posted 11-17-2014 10:39 PM
Its tite bond #1 i believe. Possibly #2 but im pretty sure 1. I’d have to check when i get home.
joeyinsouthaustin
#3 posted 11-17-2014 10:48 PM
Tite bond I or II is a pva glue. A heat gun can help. Or careful sanding.
Read here
TheWoodenOyster
1313 posts in 1931 days
#4 posted 11-17-2014 10:49 PM
I’d use a card scraper, but be careful to just hit the glue and not the veneer. Don’t bend the card too much and apply hard pressure. Bend it a little bit and take it easy
-- The Wood Is Your Oyster
View shipwright's profile
shipwright
7980 posts in 2793 days
#5 posted 11-17-2014 10:58 PM
With thin veneered plywood it can be a little scary. Hide glue, either hot or liquid would have solved the problem as it can be removed with cold water and a scrubbing pad and will not affect your finish. With PVA, I guess I’d cross my fingers and scrape with a razor blade. ...... but I’m really a hide glue guy.
trevorlamont
#6 posted 11-17-2014 11:08 PM
I’m still new to woodworking and learning. I didn’t know there were so many different kinds of glue even.
joeyinsouthaustin
#7 posted 11-18-2014 05:38 PM
Combine the card scraper with a heat gun. Soften the PVA glue and scrap it off. Then finely sand so you can still stain if needed. It may cause you an issue if you are staining.
