Ummm...a little help here
« back to Coffee Lounge forum
Forum topic by Lane posted 11-17-2014 07:58 PM 860 views 0 times favorited 8 replies Add to Favorites Watch
View Lane's profile
39 posts in 3655 days
11-17-2014 07:58 PM
Topic tags/keywords: question
Building a small box and I’ve made the classic blunder…not triple checking the poles on the magnets I used as a closure. The epoxy package says to clean up excess glue with mineral spirits, rubbing alcohol, etc. If I let a little of one of those seep down around the magnet, will that dissolve enough epoxy to allow me to get the magnet out and fix this?
Any other ideas would be welcome.
8 replies so far
View DrDirt's profile
4421 posts in 3677 days
#1 posted 11-17-2014 09:03 PM
Once the epoxy cures, the alcohol will not do anything to it.
Alcohol and/or mineral spirits, only will clean away the gooey uncured epoxy or squeeze-out.
It will not dissolve hardened epoxy.
View GregD's profile
788 posts in 3071 days
#2 posted 11-17-2014 09:28 PM
Gonna hafta drill it out I imagine.
-- Greg D.
117032 posts in 3512 days
#3 posted 11-17-2014 09:43 PM
Not much dissolves epoxy without damaging your wood can you just cut out part of your wood and ad a tab like in the photo below with different color wood with a magnet put in with the correct polarity in the tab.
-- wood crafting & classes
View JoeinGa's profile
7733 posts in 1942 days
#4 posted 11-17-2014 11:17 PM
Or add a 2nd magnet (in the correct orientation, of course) next to the first. Tell folks you used 2 to make sure it stayed shut.
View Picklehead's profile
1041 posts in 1864 days
#5 posted 11-17-2014 11:53 PM
Don’t ask me how I know how hard neodymium magnets are!
-- You've got to be smarter than the tree.
View tls's profile
3 posts in 2365 days
#6 posted 11-18-2014 12:23 AM
Trying heating the magnet with a heating iron. It will melt the glue, so you can get the magnet out(with luck).
-- Travis
View Lane's profile
#7 posted 11-18-2014 04:45 PM
I’ll try the heating iron first. Can’t see that it would hurt even if it doesn’t work. If that fails, I believe I can make a tab like Jim suggested…once I find a suitable block.
Thanks, folks.
View Blackie_'s profile
4856 posts in 2447 days
#8 posted 11-18-2014 07:42 PM
Lane, best to use a heat gun that reaches a temp of over 400 degrees.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at
