Designing a wooden pocket door mechanism (like for an entertainment center)
Forum topic by CharlesA posted 11-17-2014 02:12 AM 3183 views 0 times favorited 11 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3302 posts in 1672 days
11-17-2014 02:12 AM
Topic tags/keywords: question
I want to pick your brains. I want to make a shoe rack with a pocket door mechanism, similar to what is often used in entertainment centers. One can buy these mechanisms, sometimes north of $100. Rockler sells this one for for around $60.
I have some leftover european style hinges I can use, so I was wondering if it would be feasible to design a wooden sliding mechanism. Thoughts?
11 replies so far
View Paul Maurer's profile
Paul Maurer
162 posts in 1429 days
#1 posted 11-17-2014 04:53 AM
Not sure that I understand you. If what you want is as shown then it is probably the way to go. On reading pocket door and shoe rack, thought, why not a drawer with the side open instead of the top. – Mounting the drawer slides L/R at the top- Kiss and inexpensive. If you wanted to change the aspect once open, hinge an inner box to the front of the drawer. Pull the drawer open pivot the shoe rack on the hinges. Good luck.
-- Psalm 62: 11 Once God has spoken; twice have I heard this: that power belongs to God, 12 and steadfast love belongs to you, O Lord. For you repay to all according to their work
View Paul's profile
Paul
721 posts in 1440 days
#2 posted 11-17-2014 05:07 AM
Pocket doors normally slide into a wall, or a structure that cannot be seen. I’m confused on what you are looking for.
Paul
CharlesA
#3 posted 11-17-2014 10:22 AM
Paul, iyes, it is confusing. This type of door is also called a pocket door sometimes.
This type of kit involves euro hinges and then a door slide I was just trying to fugure out if I could reasonably design/construct the door slide. Because it involves a tall door and a short contact area for the slide, I couldn’t think of a design that wouldn’t easily rack.
View bkseitz's profile
bkseitz
295 posts in 1185 days
#4 posted 11-17-2014 10:58 AM
You might try building a frame to hold the hinges in two t-tracks instead of drawer slides
-- bkseitz, Washington "if everything is going well, you've obviously overlooked something"
View JeffP's profile
JeffP
573 posts in 1266 days
#5 posted 11-17-2014 01:55 PM
You mentioned “entertainment cabinet” in your post. That is the only use of this sort of “slide the door back out of sight when it is open” I have ever seen.
My primary thought about this rather complex mechanism is…I have never seen one that wasn’t just permanently “hidden”. In other words, people just leave the opening open and the fancy sliding door is just a waste.
Is this really just a skills challenge and a way to “get rid of” your extra european hinges? Or do you think you will ever actually close this one?
-- Last week I finally got my $*i# together. Unfortunately, it was in my shop, so I will probably never find it again.
CharlesA
#6 posted 11-17-2014 03:12 PM
Jeff, good question. It is for a shoe rack in our bedroom that would end up being open much of the time, it could be closed when we have company, etc.
View AlaskaGuy's profile
AlaskaGuy
3797 posts in 2184 days
#7 posted 11-17-2014 09:58 PM
Just an off the wall idea that I don’t have time to check out myself but, maybe something like the doors on a barrister bookcase only vertically instead of horizontal.
CharlesA
#8 posted 11-17-2014 09:59 PM
Good idea.
This is in the idea stage with my wife, and she has now moved to another idea from this one!
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1947 days
#9 posted 11-17-2014 10:15 PM
Those glides can be bought for much less, if the size is not huge. And you can buy them without the hinges, and use your own, to save money. IMO it would not be worth it the try and execute the slides out of wood. Racking will be a problem. The following strip is enough to, in combination with the bearing glides, to keep the slide from racking. FWIW if you really want to DYI you can adapt regular drawer glides to work with a following strip and euro hinges, but by the time you go through opportunity cost you have bought the real deal. Below you will find them for half the rockler price, and if you search a little more you will find them for even less.
http://www.cabinetparts.com/g/kv-8080-pivot-door-slides":http://www.cabinetparts.com/g/kv-8080-pivot-door-slides
-- Who is John Galt?
Paul Maurer
#10 posted 11-17-2014 10:37 PM
How about hanging the “pocket door” from the top like a closet door? just spit balling…
JeffP
#11 posted 11-18-2014 12:54 PM
Anybody who knows me well enough to be invited to my house is probably prepared for the reality that they will be forced to look at all of my shoes while they are there…both pairs.
My primary thought about this rather complex mechanism is…I have never seen one that wasn t just permanently “hidden”. In other words, people just leave the opening open and the fancy sliding door is just a waste.
- JeffP
