Making a CNC machine from wood. Need Advice
« back to CNC Woodworking forum
Forum topic by SoonerMike posted 11-14-2014 09:28 PM 1502 views 1 time favorited 16 replies Add to Favorites Watch
View SoonerMike's profile
SoonerMike
14 posts in 1218 days
11-14-2014 09:28 PM
Topic tags/keywords: question arduino cnc straightening wood
I’m using my Arduino to make a simple CNC setup. My current setup is made from cardboard and hangs from my whiteboard, and helps me plot. I’m going to be making one from wood, and I’d like to know how I can make wooden rails that stay fairly straight. I was thinking of making a sandwich, or some fancy shape to keep it stable. Due to budgets, I’ll have to use basic lumber from Lowes or something and rip it on my table saw and glue/screw it together. That’s about all I’m capable of right now. Any help would be much appreciated?
-Mike
-- I'm pretty sure this'll work.
16 replies so far
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3488 days
#1 posted 11-14-2014 09:37 PM
I would surely stick with the cardboard that’s how everyone else here made their cnc masterpieces.I assume this is a JOKE after all.Alistair
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3616 days
#2 posted 11-14-2014 10:42 PM
I don’t think Mike is joking but asking a pretty good question. As I understand it he has a CNC that he prototyped out of basic materials and is using it to draw things on a white board. A pretty clever approach to learning how to get an Arduino to do what you need it to do. Mike then goes on to ask how he could build a more robust version now that (presumably) his prototype solved enough questions for him that the is ready to step up his game.
Mike I am not sure how big you are building this but you may want to explore the use of 1) Baltic birch plywood, 2) hardwoods such as maple or oak and 3) check out some of the stuff that Mathais Wandel has done on his Woodgears website for inspiration in building machines in wood. If you haven’t already you may want to check out the projects section here as I believe a number of LJs have built CNC machines. Blog the process and I am sure the folks here that have actually build CNC machines may be able to chime in with some useful comments. Looking forward to seeing progress pictures!
View JAAune's profile
JAAune
1780 posts in 2220 days
#3 posted 11-14-2014 11:03 PM
Laminations are an excellent way to minimize warping. An alternative is to attempt stabilization using Cactus Juice or some similar agent.
SoonerMike
#4 posted 11-18-2014 01:26 PM
Yeah, you’d think I was joking on this, and I do joke around a lot, but not when it comes to cardboard. That’s some very serious business. lol. Cardboard is a terrific prototyping material because it’s cheap, easy to work with, and fairly strong. I’ve built victorious boats, shelving, foam cutters, artwork, windmills, and all sorts of stuff from cardboard. If needed, I then convert to something more permanent.
Thanks guys. -Mike
View ChuckC's profile
ChuckC
827 posts in 2838 days
#5 posted 11-18-2014 01:53 PM
Check out the JGRO design on cnczone.com. I have one on my projects page. It wasn’t that hard to make and remarkably accurate considering what it’s made from.
SoonerMike
#6 posted 11-18-2014 02:04 PM
Thanks Chuck! That thing is really neat.
View brtech's profile
brtech
1017 posts in 2826 days
#7 posted 11-18-2014 03:47 PM
Also consider torsion box construction. Use 1/4” ply. You can get flat, square, strong and lightweight beams out of that. Consider that for the cross beam at least.
View Mike's profile
Mike
406 posts in 2590 days
#8 posted 11-18-2014 04:08 PM
How about using drawer rails and channel track? The BBS have tones of the stuff. People use the rails from shower doors all the time.
-- look Ma! I still got all eleven of my fingers! - http://www.lepelstatcrafts.etsy.com - https://www.youtube.com/channel/UCppWfrYGXCr5lm9uW-Fpqqw
ChuckC
#9 posted 11-18-2014 04:20 PM
^^ There is way too much lateral movement in draw slides for a cnc. One of the cheapest ways to go is gas pipe and bearings.
View oldnovice's profile
oldnovice
6543 posts in 3271 days
#10 posted 11-18-2014 04:31 PM
SoonerMike, do you mean corrugated board or cardboard?
I ask this because for a number of years I supported automation in corrugated board manufacturing and they prefer, and are downright adament, that their product is NOT cardboard.
SoonerMike
#11 posted 11-18-2014 04:35 PM
Wow! I love all the suggestions. oldnovice, I use corrugated cardboard for all my prototypes. You know, the kind of stuff boxes are made from? That’s what I consider cardboard, except I buy mine in 4×8 sheets so it’s consistent.
brtech
#12 posted 11-18-2014 05:18 PM
Do you know about this stuff:
http://openbuildspartstore.com/
It’s so cheap, you might reconsider wood. Depends on how big you want to make your CNC.
View ChadRat6458's profile
ChadRat6458
89 posts in 1258 days
#13 posted 11-19-2014 02:00 PM
Mike, I am in Piedmont, Ok. I have a mig welder if you want to use steel. I am interested in CNC routing. Doing research on the best way to go. The Joe’s hybrid setup looks good. Let me know if I can help.
Chad
-- WWW.SKYKAE.COM - Custome Wood Furniture and Signs WWW.FACEBOOK.COM/SkyKae.Kreations
oldnovice
#14 posted 11-19-2014 08:04 PM
SoonerMike, do you realize that by bonding two sheets at right angles to another sheet provides a very strong sheet of material. By adding more layers you can make some really strong material!
In fact, here is a video of a bicycle made from corrugated board
SoonerMike
#15 posted 11-19-2014 08:15 PM
Old Novice: I regularly make my own “plyboard” by gluing sheets at 90 degrees. That bicycle is awesome! I’d call that a honey comb panel, but I see now what you mean by corrugated board. I started using cardboard because corrugated board wasn’t legal for the boat competitions.
