Anybody tried the $60 HF drill press
Forum topic by shipwright posted 11-14-2014 09:17 PM 2432 views 0 times favorited 36 replies Add to Favorites Watch
View shipwright's profile
shipwright
7847 posts in 2668 days
11-14-2014 09:17 PM
I need a small, cheap drill press for square drilling of veneer packets. The only reason that I haven’t bought one of these HF ones before is that the chuck is less than a precision grind and I need to grip #74 drill bits. I just ordered some carbide bits that have 1/8” shanks so that problem should be gone. I’m just wondering if anyone has any other complaints about them before I blow my life savings on one.
(I will be taking a 1/8” bit with me to make sure the one I get will actually clamp it.)
Thanks in advance.
36 replies so far
View Sodabowski's profile
Sodabowski
2370 posts in 2703 days
#1 posted 11-14-2014 09:27 PM
Paul, why not invest in a cheap auxiliary mandrel? these come in all flavours, I like those with a standard 1/4” hex shank, but the round ones are okay too. You can put very small bits in these :
http://www.ebay.fr/itm/Micro-small-pin-chuck-vice-HOLDS-VERY-TINY-DRILLS-BURRS-tools-3-collets-0-2-5m-/191059606795?pt=UK_Home_Garden_PowerTools_SM&hash=item2c7c0a3d0b
-- Thomas - Pondering the inclusion of woodworking into physics and chemistry classes...
View Joe Lyddon's profile
Joe Lyddon
9979 posts in 3922 days
#2 posted 11-14-2014 09:29 PM
I have been using one for years… No problem with 1/8” bits!
The only problem I have had is it’s flimsy Depth-Stop adjustment…
... other than that, works OK for me…
I don’t know how it handles Metal… I have only used it for wood, plastic, etc.
Once in awhile, they have them on sale & you can get them for $50…
For those really small bits, you can always get a little chuck from Lee Valley that you can put into the DP and then put the small bits into the chuck…
Have fun,
Joe
shipwright
#3 posted 11-14-2014 09:31 PM
I actually have one of those already Thomas. I was planning to buy this DP this year anyway, before I found the carbide bits …... as long as no one has any deal breaker complaints.
Thanks
View RogerBean's profile
RogerBean
1605 posts in 2824 days
#4 posted 11-14-2014 09:31 PM
HI Paul,
My greatest concern with the inexpensive DP’s is the quality of the chuck. I’ve seen many with very visible wobble or runout. Might have to kiss a few different frogs to find a prince in the inventory. Of course you could replace the chuck with something better, but then, it’s no longer $60.
Roger
-- "Everybody makes mistakes. A craftsman always fixes them." (Monty Kennedy, "The Checkering and Carving of Gunstocks", 1952)
bandit571
18893 posts in 2553 days
#5 posted 11-14-2014 09:42 PM
Bought a $70 5 speed at H-F years ago, no problems other than it was missing a set screw in a drive pulley. Fixed that for a whoppingly expensive $0.49+tax
Have been drilling wood/metal ever since.
Chuck IS a Jacobs chuck, came with the drill press BTW
View JoeMcGlynn's profile
JoeMcGlynn
219 posts in 2224 days
#6 posted 11-14-2014 10:02 PM
It’s probably OK, but besides the ability of the chuck to grip a small bit (which you’ve solved) I’d think about run out too. That could be a problem with a small carbide drill. Most likely it’s OK though.
A fall back is either an add-on chuck like above, or just replace the chuck on the machine with a smaller precision Jacobs chuck…although that might cost more then the HF drill press by itself.
-- Blog: http://mcglynnonmaking.wordpress.com/
View JAAune's profile
JAAune
1772 posts in 2187 days
#7 posted 11-14-2014 10:40 PM
We’ve got two of them that were purchased over a year ago to hold branding irons. The quills have a lot of slop and even with plenty of fiddling, they still wobble too much on the down-stroke. I’d never use them for drilling holes but they’re serviceable for branding (though barely).
I’d spend an extra $25 and get one with slightly better quality control.
shipwright
#8 posted 11-14-2014 10:52 PM
Thanks for the replies everyone. I think I’ll go in, check the chuck, check the quill for wiggle and make my decision. Small and cheap are the main factors as I don’t have much space and I have my ShopSmith which is a great drill press. As long as this can drill holes less than a degree or two off square, it will likely do. If not, I’ve never had a problem with a return at HF.
View jmartel's profile
jmartel
7622 posts in 2020 days
#9 posted 11-14-2014 11:02 PM
Those 5 speed drill presses get some pretty good reviews for the price. I have the 12 speed benchtop from HF. It does ok, but has some runout/wobble. It has a bigger motor than the 5 speed, and it still bogs down on occasion. For 1/8” bits, you should be fine. Keep in mind that it has a pretty small depth that it can reach to in the center of a packet. I think 5” maybe?
My benchtop will be replaced with a floor model with a longer quill travel in the future, but for now it works.
JAAune
#10 posted 11-14-2014 11:05 PM
The little ones we purchased have a 3” stroke.
jmartel
#11 posted 11-14-2014 11:14 PM
I was referring to the distance from the center of the bit to the post. In this case, it’s 4” for the model Paul is talking about. Stroke is only 2”.
http://www.harborfreight.com/8-in-bench-mount-drill-press-5-speed-60238.html
This is the model I have
http://www.harborfreight.com/10-in-bench-mount-drill-press-12-speed-60237.html
View InstantSiv's profile
InstantSiv
259 posts in 1465 days
#12 posted 11-14-2014 11:22 PM
I have 2. If you’re not expecting much from them they are an amazing value.
Only thing that concerns me though is that 5+ minutes on the older version(pre-light) and the motor will get very hot. Haven’t really run the newer version that long so I don’t know if it has the same issue.
JAAune
#13 posted 11-14-2014 11:37 PM
Throat distance you mean? Yes, I’d forgotten how small that is.
There’s something to be said for just making a guide block out of a piece of hardwood then setting that on top of the material to be drilled. I’ve done some very straight holes with that technique on all sorts of items that wouldn’t fit on the drill press.
shipwright
#14 posted 11-14-2014 11:43 PM
Quill travel isn’t important to me. 1” would do. Power, same thing. The drill bit is .0225”.
The throat capacity however could be a deal breaker. Thanks for pointing that out Jeff.
As for a guide block, the exposed drill length here is maybe an inch and the packet can be very nearly that thick.
shipwright
#15 posted 11-14-2014 11:52 PM
This is what I’m using right now.
With all it’s wobbling it is almost good enough. It can however make a hole in the centre of a very large piece.
I’m thinking if I shorten the post and cut the centre out of the base, I may end up with a more accurate One of the above.
showing 1 through 15 of 36 replies
