Flat Paint Farmhouse Table
Forum topic by Dan posted 11-14-2014 02:31 PM 1064 views 0 times favorited 6 replies Add to Favorites Watch
View Dan's profile
106 posts in 2757 days
11-14-2014 02:31 PM
Topic tags/keywords: table paint finish
I am working on restoring an old Charleston style round table that had a painted base and a solid mahogany top. I am looking to refinish the base but am not sure how to get that flat farmhouse style look. I will probably need to go with a darker color like a flat black or dark green. Does anyone have any advice on how to do this?
This table needs a ton of repair work done beforehand but I want to make sure I am prepared for the finishing steps.
-- Will work for wood...
View ElChe's profile
630 posts in 1267 days
#1 posted 11-15-2014 04:40 AM
Take a look at milk paint. Might be what you are looking for?
View emart's profile
445 posts in 2559 days
#2 posted 11-15-2014 04:56 AM
just about any paint can become flat when mixed with corn starch if memory serves me correct
-- tools are only as good as the hands that hold them
View endgrainy's profile
251 posts in 1819 days
#3 posted 11-15-2014 06:21 PM
+1 for milk paint. Though not a true milk paint, I’ve used General Finishes milk paint on a couple projects with good success:
A popular trend seems to be using a base color followed by a different top color. You then sand the top coat down to varying levels to get the aged look:
-- Follow me on Instagram @endgrainy
View bondogaposis's profile
4632 posts in 2282 days
#4 posted 11-15-2014 06:58 PM
Milk paint is what you want.
-- Bondo Gaposis
View Dan's profile
#5 posted 11-17-2014 02:21 PM
Thank you all for the ideas. I looked at milk paint but cannot find a source locally and need to finish the table by the end of the week. I came up with a multilayer-ed satin finish that might give me similar results. I am going to use coats of different colored paint and then sand through the top layer and distress the legs a bit. After that will put a polyacrilic clear coat to add some durability. Will this look ok?
#6 posted 11-18-2014 10:17 PM
the clear coat might make the finish glossy again unless you knock it down a bit with sandpaper
