lathe stand
« back to Woodturning forum
Forum topic by 3285jeff posted 11-14-2014 12:15 PM 1183 views 0 times favorited 7 replies Add to Favorites Watch
View 3285jeff's profile
3285jeff
152 posts in 1682 days
11-14-2014 12:15 PM
im going to build me a lathe stand for my lathe ,,,what would anyone consider to be the proper height,,im 5:7,,thank you for your comments
7 replies so far
View hairy's profile
hairy
2655 posts in 3496 days
#1 posted 11-14-2014 12:59 PM
Generally, you want the lathe drive spindle to be about elbow height.
-- My reality check bounced...
View LeeMills's profile
LeeMills
522 posts in 1265 days
#2 posted 11-14-2014 01:01 PM
Most people prefer about center height of the spindle to be elbow height. I like mine about 1.5” higher. Make sure you anticipate riser blocks between the stand and the lathe to make chip removal easier.
View Nubsnstubs's profile
Nubsnstubs
1280 posts in 1694 days
#3 posted 11-14-2014 01:16 PM
Jeff, from what I’ve heard, the head stock center should be the heigth of your elbow. I built mine about 4” higher because I broke my neck about 5 years ago, and now I don’t have to bend my neck as much. I think the elbow dimension is a starting point.
Set your lathe on a table, put some wood build up under it until you get to a comfortable height. Then you will have a starting point to work from. .............. Jerry (in Tucson)
View Minorhero's profile
Minorhero
373 posts in 2569 days
#4 posted 11-14-2014 01:56 PM
Vibration is your biggest issue with a stand. Definitely overbuild it and make sure you have a way of locking the stand directly to the ground and not just on wheels. Also consider having a spot you can fill with rocks or sand for added weight.
View TheDane's profile
TheDane
5399 posts in 3627 days
#5 posted 11-14-2014 03:07 PM
What lathe did you wind up buying?
View Wildwood's profile
Wildwood
2297 posts in 2099 days
#6 posted 11-14-2014 03:31 PM
Here is one man’s thought process which should allow you make something with materials you have on hand.
http://www.cranialstorage.com/Wood/lathe_stand.html
Have made three wood lathe stands over the years two had splayed legs for stability and one for a mini lathe had square legs. Used the same thought process for measuring stand height outlined in the article.
Today will see folks building cabinets on wheels, splayed legs, and trestle leg styles designed lathe stands.
-- Bill
TheDane
#7 posted 11-14-2014 06:30 PM
Here’s mine … not so much a stand as a rolling cabinet:
Click for details
