Duplicating help.
« back to Woodturning forum
Forum topic by Keith Sonefelt posted 11-13-2014 05:17 AM 931 views 0 times favorited 7 replies Add to Favorites Watch
View Keith Sonefelt's profile
Keith Sonefelt
18 posts in 1254 days
11-13-2014 05:17 AM
Can anyone help me with something. I have a real hard time making 2 of something the same. I don’t do enough to justify a duplicator. Tried making a salt and pepper shaker (not grinders, but actual shakers). It was obvious they were not even close to the same. Glad these were “try out” projects instead of for a customer.
Suggestions???
-- "If it's worth doing, it's worth doing right"
7 replies so far
View TheFridge's profile
TheFridge
8854 posts in 1389 days
#1 posted 11-13-2014 05:32 AM
Some kind of pattern jig? Necessity is the mother of invention.
View Rick_M's profile (online now)
Rick_M
11095 posts in 2283 days
#2 posted 11-13-2014 05:33 AM
View hairy's profile
hairy
2606 posts in 3435 days
#3 posted 11-13-2014 12:36 PM
What works for me is putting it on paper first. A full size, inside and outside drawing. With that you decide when to do what, a step by step plan.
-- My reality check bounced...
View oldnovice's profile
oldnovice
6543 posts in 3271 days
#4 posted 11-13-2014 05:36 PM
I don’t know about turning but for other duplications I make templates for my router which sometimes require more than one template. The repeatability is as good as the template setup!
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2273 days
#5 posted 11-13-2014 06:28 PM
http://lumberjocks.com/topics/59689
A cool jig by a member here that helps you to duplicate measurements for various points on your turnings. Plans are from PW magazine.
View SCOTSMAN's profile
SCOTSMAN
5845 posts in 3488 days
#6 posted 11-13-2014 06:55 PM
Try to make a double pointed holder directly behind your lathe, and it must be on centre with both points like a headstock and a tailstock points.Then fit the original piece you turned, directly behind the new one you intend to make it becomes much easier to eyeball it that way also measurements are easier to transfer.I always turn to a cylinder first always never try to copy from square stock IMHO Have fun Alistair
View bigblockyeti's profile
bigblockyeti
4981 posts in 1624 days
#7 posted 11-13-2014 07:07 PM
You can use a contour gauge like this one: http://www.homedepot.com/p/QEP-10-in-Contour-Gauge-10032Q/202097525 It will allow you to make a pattern stick if your trying to duplicate something you have or already made.
