air cleaner
Forum topic by brodd5 posted 11-12-2014 04:33 PM 907 views 0 times favorited 11 replies Add to Favorites Watch
View brodd5's profile
brodd5
6 posts in 1196 days
11-12-2014 04:33 PM
I have plans to make an air cleaner for my garage, but having trouble finding a cost effective blower.
I have just about contacted all the HVAC companies in my area and no one has any used ones. Can anyone give me some tips on where I might find one at a reasonable cost ?
11 replies so far
View Rayne's profile
Rayne
734 posts in 1444 days
#1 posted 11-12-2014 04:35 PM
I made these for my garage and they are working great. If you need something more powerful, then yeah, these won’t be the best, but at least it was cost effective. :)
http://lumberjocks.com/projects/105079
View timbertailor's profile
timbertailor
1594 posts in 1329 days
#2 posted 11-12-2014 04:39 PM
Filters that will remove down to 1 or 0.5 microns while capable of meeting the flow requirements generated by a HVAC blower are also very expensive.
I suggest starting here to understand the dangers of fine particles and what it takes to remove them for the work shop SAFELY.
The last thing you want to do is blow the small particles back into the air, over and over again.
View bigblockyeti's profile
bigblockyeti
4984 posts in 1625 days
#3 posted 11-12-2014 05:00 PM
I remember when you could pick up a blower for free or maybe $5. I think scrap prices having increased over time may have put an end to that. The comment about the filter is very true, on the plus side, most furnace blowers are three speed and the lowest speed should move close to the air that a manufactured unit would move on high.
View rantingrich's profile
rantingrich
372 posts in 1250 days
#4 posted 11-12-2014 05:23 PM
Have you considered an ELECTRIC Air Filter/cleaner
-- Rich
View MakerofSawdust's profile
MakerofSawdust
35 posts in 2521 days
#5 posted 11-12-2014 05:26 PM
I was curious and just searched Craigslist in my area (Cincinnati) for “blower motor” and there are a few choices for $30-$50. Have you tried Craigslist? I’m not sure if that qualifies as a reasonable cost for you.
-- - Kevin from Cincinnati. All my work is guaranteed: Three minutes or three feet; whichever comes first.
brodd5
#6 posted 11-12-2014 07:31 PM
Thanks for all the replies, I have checked craigslist in my area . I have found one on Amazon which normally is $90.00 , there is a slightly used one for $53.87. My problem is, is it good enough and will it actually pull most of the dust out of the air , using 3 filters. When it is nice out I work outside, but when it is cold or raining I close the garage door. Last winter everything was coated with dust created while doing woodworking. I only occasionally work on any project depending on how I feel. Right now I am in the midst of making 8 sets of outdoor shutters, which is going to create a whole lot of dust with the door closed. The air cleaners they sell are far to pricey for my budget. I had thought of the box fan type, but I much rather have something with more power, which I hope would clean the air from the dust particles more efficiently
brodd5
#7 posted 11-12-2014 07:48 PM
Hurricane Fans 180 CFM Blower -This is the blower that I am Considering it is 10×9x9 and comes with a 10 foot Grounded power cord pre-wired. it appears to be a single speed
View buildingmonkey's profile
buildingmonkey
242 posts in 1452 days
#8 posted 11-13-2014 01:40 AM
Look at woodgears.ca I did a search and found it, and he had a dust bag on a furnace blower for a air cleaner. Simple and cool.
-- Jim from Kansas
timbertailor
#9 posted 11-13-2014 02:01 AM
So what is the flow of the filters you are planning on using and what percentage of material are they capable of removing? How far down do they filter to? How much surface area is being provided by the filter? How long can you use it before it clogs or needs to cleaned\replaced?
I am amazed at how many “great ideas” I see slapped together on this forum with absolutely NO research done on what is required to accomplish the task, even when presented with the material required to comprehend the dangers of fine particles.
Lots of experimentation going on with little or no appreciation for the danger it poses to ones long term health.
timbertailor
#10 posted 11-13-2014 02:05 AM
Deleted. LumberJocks servers are overwhelmed. They have become slow, and even unresponsive.
timbertailor
#11 posted 11-13-2014 02:05 AM
