Ogee feet material
« back to CNC Woodworking forum
Forum topic by bonesbr549 posted 11-11-2014 05:57 PM 1024 views 0 times favorited 3 replies Add to Favorites Watch
View bonesbr549's profile
bonesbr549
1494 posts in 2976 days
11-11-2014 05:57 PM
thinking to myself and was wondering if it would be worthwhile to make ogee feet (6” wide) via a cnc router? I use sketchup regularly and have an ogee pattern I created, and was noticing that there is an add-in now sketchu-cam that will convert to g-code.
I make wine cabinets and was thinking this would spead production of the parts to make the feet. It might be easier to go the shaper router I guess.
3 replies so far
View Puzzleman's profile
Puzzleman
417 posts in 2853 days
#1 posted 11-12-2014 12:23 PM
Your answer depends on haw many wine cabinets you make. Not all things are possible to create efficiently with a cnc. You process may be faster without one.
A way to test your idea, is to find someone local who has a cnc. See if they will run it for you. this way you find out what is possible, the amount of time and the cost. Again depending on your volume of work, it make more sense to out source that part.
-- Jim Beachler, Chief Puzzler, http://www.hollowwoodworks.com
View MoosetraxCarvedSigns's profile
1 post in 1199 days
#2 posted 11-13-2014 08:54 PM
I do alot of cnc carving and if I understand you properly, I would think it would be faster to make a template for a table router (assuming you have one) and then rough cut the legs on a bandsaw and finish on the router. Unless your mass producing your wine cabinets, I think the cnc method would be a little overkill.
-- Moosetrax
bonesbr549
#3 posted 11-13-2014 11:10 PM
Thanks for the replies. I normally do them on the router table, but the number of passes are getting old. Plus the time required to finish them with sanding is getting old. I was hoping this profile could be done on the CNC and just let it go and run while I do other things. When I do them I could do multiples.
