I need some help with my table saw.
Forum topic by jwhaneman posted 11-10-2014 04:44 PM 797 views 0 times favorited 3 replies Add to Favorites Watch
View jwhaneman's profile
1 post in 1228 days
11-10-2014 04:44 PM
I have a Grizzly table saw. Lately my saw blade rises on its own as the saw is running. I’ve tried tightening the height adjustment wheel but to no avail. Can anyone help?
3 replies so far
View mahdee's profile
3852 posts in 1701 days
#1 posted 11-10-2014 04:53 PM
Not sure about your saw, but most of them use a combination of two gears to raise and lower. Perhaps the clearance between the two gears has increased. Look at the mechanism that raise/lower the blade and you should be able to pinpoint the problem.
View Tedstor's profile
1643 posts in 2567 days
#2 posted 11-10-2014 04:58 PM
Call Grizzly. Their tech line should be able to hook you up.
2694 posts in 1959 days
#3 posted 11-11-2014 05:17 AM
Maybe there is backlash in the elevation mechanism. If so, it should be possible to adjust it out. I had a Rockwell contractor’s saw that did that, but only by a small amount (when it mattered, as when making a blind cut) and only on startup. Drove me up the wall.
