Popping the grain in curly maple without changing the color
Forum topic by TheWoodenOyster posted 11-10-2014 02:40 PM 1107 views 0 times favorited 6 replies Add to Favorites Watch
TheWoodenOyster
1313 posts in 1836 days
11-10-2014 02:40 PM
Topic tags/keywords: curly maple
Hey guys,
The title pretty much explains it. I am using some curly maple for the first time and I am trying to keep the color of the maple as close to the natural white as possible while still popping the curl out. I was thinking about just using straight polycrylic, but I’m worried I won’t get any grain pop with that. I’m not sure if there is a solution to this, but I figured I’d at least ask.
Thanks again
-- The Wood Is Your Oyster
View RogerM's profile
RogerM
790 posts in 2300 days
#1 posted 11-10-2014 03:00 PM
No can do. Projects of curly maple pop because of contrasting colors. One way that might get close would be to use a water base dye (very dilute of course) allowing it to dry then lightly sand with around 180 to 220 grit sandpaper. This would put a little color in the softer grain while allow ing the harder grain to maintain it’s natural color. Please let me know what you finally go with. There would be a lot of ways to get similar results. Also, note my curly maple cabinets on my projects page.
-- Roger M, Aiken, SC
View firefighterontheside's profile (online now)
17508 posts in 1758 days
#2 posted 11-10-2014 03:04 PM
I think the polycrylic might do a little for ya, at least better than plain water based poly. I just put it on some cherry and it did better than I thought it would. My next best suggestion would be oil based poly, but that will Amber it a bit.
View waho6o9's profile
waho6o9
8097 posts in 2478 days
#3 posted 11-10-2014 03:21 PM
Interesting question. Maybe practice on some scraps until you find
something you like?
View Rick  Dennington's profile (online now)
Rick Dennington
5684 posts in 3096 days
#4 posted 11-10-2014 03:47 PM
If you want to see what the curly maple will look like, and pop the grain, just wipe it down with mineral spirits….then , if you like that look, wipe on some Danish Oil (natural), and it will really pop…..Practice on some scrap pieces first to see if it’s what you want…..If not, then go another direction…..
-- " Don't pet the sweaty things, and don't sweat the petty things."
View Ripthorn's profile
Ripthorn
1454 posts in 2886 days
#5 posted 11-10-2014 03:53 PM
Go get a can of Krylon crystal clear coat. I have used it on multiple guitar necks. It was the winner after testing with several different methods to do exactly as you intend to do. The figure popping is really amazing and the cost and ease of application make it a no-brainer. I went through trials with a ton of scraps and this was the best. Even got a commission based purely on the finish on the neck of a guitar I built for myself using this approach. Oils are great, but darken the color too much. Analine dyes don’t result in as much 3D and depth in the end, and polycrylic didn’t provide enough contrast. I don’t remember what else I tried off the top of my head.
Edit: I have no affiliation with Krylon, just a satisfied customer with a $3.84 can.
TheWoodenOyster
#6 posted 11-10-2014 04:55 PM
Thanks guys. I will give these suggestions a try on some scraps. Definitely interested in the krylon option, I actually think I have a can of that sitting around. Is the texture gritty though? And if so, do you just sand it down with 0000 steel or 1500 sandpaper or so?
