Finishing MDF edges
Forum topic by PRGDesigns posted 11-10-2014 02:26 AM 2721 views 0 times favorited 14 replies Add to Favorites Watch
View PRGDesigns's profile
PRGDesigns
235 posts in 2218 days
11-10-2014 02:26 AM
Topic tags/keywords: question tip finishing
I cut a number of shapes out of the Plum Creek Premium MDF. When I try to paint the edges, the MDF appears to absorb the primer / paint like a sponge. I am seeking a cost effective and efficient method / product to produce acceptable painted edges on MDF.
I currently use Kilz oil based primer spray paint followed up with various brands of spray paint for a finish coat.
In my inquiries to date, I have learned of the latex caulk method and the drywall mud technique. Any additional information you can share on these techniques is much appreciated.
Thanks in advance for any consideration you can give this matter.
-- They call me Mr. Silly
14 replies so far
View Sawdust4Blood's profile
Sawdust4Blood
397 posts in 2926 days
#1 posted 11-10-2014 02:35 AM
I know guys that use auto body filler (aka bondo) for a hard smooth surface that paints or lacquers well.
-- Greg, Severn MD
17542 posts in 1761 days
#2 posted 11-10-2014 02:38 AM
Mix up some glue and water and paint it on the edges. Not sure of the ratio, but guessing half and half.
View bondogaposis's profile
bondogaposis
4599 posts in 2256 days
#3 posted 11-10-2014 02:52 AM
I use drywall joint compound.
-- Bondo Gaposis
View Flipper01's profile
Flipper01
39 posts in 1208 days
#4 posted 11-10-2014 02:55 AM
Sawdust and Titebond or your favorite glue. Hard spackle knife and press hard into the edges. Let dry overnight, sand smooth and prime and paint. Never failed me in 30+ years.
View NoThanks's profile
NoThanks
798 posts in 1433 days
#5 posted 11-10-2014 03:00 AM
I’ve used everything mentioned above, and in my opinion it more work than it’s worth.
The best product I have used has been pre-cat undercoater/primer/surfacer. spray on a couple of coats, sand real good spray on one more coat and sand and it’s ready for paint.
I believe the trick is sealing the fibers deep into the edge so that when you sand it closes all the ends and smooths it up.
Problem with bondo is it’s harder than the mdf and is to hard to sand off,
and the taping mud or spackle or other fillers just get sanded off after putting it on, they don’t really seal the edges.
Anyway to each their own but that is what works excellent for me. JMO
-- Because I'm gone, that's why!
View Rick Bailey's profile
Rick Bailey
247 posts in 1267 days
#6 posted 11-10-2014 03:03 AM
I ve used everything mentioned above, and in my opinion it more work than it s worth.
The best product I have used has been pre-cat undercoater/primer/surfacer. spray on a couple of coats, sand real good spray on one more coat and sand and it s ready for paint.
Problem with bondo is it s harder than the mdf and is to hard to sand off,
and the taping mud or spackle or other fillers just get sanded off after putting it on, they don t really seal the edges.
- Iwud4u
+ 1
Me too.
-- I'll bulid your dream,you tear it down.
View wseand's profile
wseand
2796 posts in 2946 days
#7 posted 11-10-2014 05:45 AM
Shellac…
View randy5566's profile
randy5566
1 post in 1198 days
#8 posted 11-10-2014 08:38 AM
and the taping mud or spackle or other fillers just get sanded off after putting it on, they don’t really seal the edges.???
aaaaaa
View doitforfun's profile
doitforfun
199 posts in 1512 days
#9 posted 11-10-2014 11:13 AM
+1 for joint compound. It’s cheap and easy to sand. Hand sand it and it will hold primer like crazy.
-- Brian in Wantagh, NY
View bigblockyeti's profile
bigblockyeti
4983 posts in 1625 days
#10 posted 11-10-2014 12:37 PM
I’ve tried too many different methods and found it easier to just attach a strip of whatever hardwood I have laying around to the edge. It’s much faster and far fewer headaches.
View putty's profile
putty
1179 posts in 1511 days
#11 posted 11-10-2014 01:10 PM
Someone on LJ recently recommended a 50/50 mixture of yellow glue and water. I tried it on a recent project and it worked great. I just smeared it on the edges with my finger. In the past I have tried drywall mud and caulk. I was surprised how well the dried glue mixture took paint.
-- Putty
View Moron's profile
Moron
5032 posts in 3798 days
#12 posted 11-10-2014 01:32 PM
I use Drydex, its a pink drywall touch up compound, goes on pink, dries white. Sand and re-apply until edges are smooth
PRGDesigns
#13 posted 11-11-2014 12:48 PM
Thanks to all who responded. I will try a few of these suggestions to analyze what works best for my situation.
FYI – I have hundreds of these pieces to potentially seal the edges, so an efficient solution is essential.
View dogmir's profile
dogmir
25 posts in 1877 days
#14 posted 11-11-2014 04:24 PM
I have used various products like Drydex and other compounds. Although it works they can be time consuming. I like to use Zinsser BIN Shellac based primer. It stinks and will make you loopy so I wear a respirator. Goes on and dries insanely fast which is great cause you can get a few coats on. I then use a hard sanding block to finish. That said I usually just do the whole piece with this. I know they make it in a aerosol can and I hear it sprays like a dream out of a gun. I have not tried either of those. I usually use a brush or roller.
