Central Machinery (HF) dust collector just died--any ideas?
Forum topic by CharlesA posted 11-09-2014 06:52 PM 1021 views 0 times favorited 7 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3319 posts in 1791 days
11-09-2014 06:52 PM
Topic tags/keywords: question dust collector central machinery harbor freight motor electrical
I use the 2 hp CM dust collector attached to a remote. I used it couple of times today. Then when getting ready to make a cut on table saw—clicked the remote—nothing. I’ve plugged it in to a couple of different outlets, so that’s ruled out. The switch still seems functional (it’s flips with a hard stop, not mushy).
I don’t hear anything when power is applied.
I’m good with basic electrical, but know very little about motors. I’d appreciate any ideas.
7 replies so far
View WhyMe's profile
WhyMe
1012 posts in 1554 days
#1 posted 11-09-2014 07:14 PM
Time to open it up and check for a bad/broken connection.
CharlesA
#2 posted 11-09-2014 07:22 PM
Well . . . I was wrong about the switch. I happened to have a switch around and it works with the new switch. I went back and forth several times. Definitely the switch. Unfortunately, the switch I have is a magnetic switch—doesn’t work with a remote. But at least I know what the problem is.
View bkseitz's profile
bkseitz
295 posts in 1303 days
#3 posted 11-09-2014 08:33 PM
Glad to know you’ve identified the problem and is fixable
-- bkseitz, Washington "if everything is going well, you've obviously overlooked something"
CharlesA
#4 posted 11-09-2014 10:44 PM
Apparently switch failure is common on this model. I couldn’t find a switch anywhere close. Since I use a remote, I just wired it directly with no switch on the motor itself.
View TheFridge's profile
TheFridge
9435 posts in 1479 days
#5 posted 11-09-2014 10:47 PM
It’ll be fine with out it.
View MT_Stringer's profile
MT_Stringer
3168 posts in 3224 days
#6 posted 11-09-2014 11:30 PM
My little cheep remote went out so…
I used some SO cord to fabricate an extension cord. I mounted the ON/OFF switch (regular 20 amp rated switch) in a conduit box. The extension cord runs from the the outlet on the wall to the box, which is mounted between my table saw and work bench. From the box, it is plugged into the end of the cord for the dust collector.
This has worked out well for me because the DC manifold is directly underneath the switch. I can easily switch blast gates and turn on the DC easily. Ha ha, yeah, I have a small work area.
No more troubles with the little remote. This setup is also extending the life of the motor mounted switch on the DC.
CharlesA
#7 posted 11-09-2014 11:34 PM
It feels kind of dumb to me to have a remote with my cheapy CL HF Dust Collector, but I have it stuck in a corner. I can’t even get to the switch without some work.
