OK, bear with me, 1 more Dust Deputy question
Forum topic by hairy posted 11-08-2014 05:50 PM 2293 views 0 times favorited 11 replies Add to Favorites Watch
View hairy's profile
hairy
2701 posts in 3528 days
11-08-2014 05:50 PM
I’m about ready to get the Super Dust Deputy to add on to my d/c. I’m holding out,hoping for a Black Friday deal.
I’ve seen some youtube video’s, except for hooking up to a shop vac, I’m not going there. It looks to me like you have to dismantle it to empty it. That would not be a problem on something like this.
When you get to a setup like this, it looks like a PITA.
Both of these pics are from Oneida’s web page.
What am I missing? It can’t be that hard or who would buy it?
I asked Oneida if the spec’s are the same for molded or metal cyclone. They say ” the molded is a little more efficient, and has better separation due to the way the top is inclined. Metal is recommended for abrasive materials.”
I’m still riding the fence on buying or building the bucket/wheels/braces thing. Emptying the bucket will go a long way in making a decision. I’m leaning towards a version of pic #1. Simple is good. If I go with a version of pic #2, I would make it a separate cart for the cyclone/can section, and connect it to the d/c with hoses. Someday it has to come out of the basement.
What did you do, and how is it working? Would you do it differently if you could? Thanks!!
-- My reality check bounced...
11 replies so far
View Paul's profile
Paul
721 posts in 1561 days
#1 posted 11-08-2014 07:16 PM
My setup is like picture 1, its setup in a closet in my shop with 4” runs to each of my big machines. I have a small setup so a 1.5hp dc with a 10” impellor is all I need. Works great. I have my SDD hooked uup to a fiber drum with a metal strap around the lid to seal it up.
If I had longer 4” duct runs I would, longer than 8 feet on multiple machines I would look at a bigger DC but for me my current setup is sufficient and the SDD is great.
It takes my 2 minutes max to empty the drum, its very easy.
Paul
edit – damn sideways picture
View paullhf's profile
paullhf
7 posts in 1382 days
#2 posted 11-08-2014 10:45 PM
I tried the bigger version from Oneida, their Cobra. Over all it worked good. However, I found the barrel too small, removing the top to get to the barrel tiresome, and I fouled the HEPA filter quickly. I built my own barrel style system using of all things a WORX leaf blower drawing down through a 3 micron bag backed up by a 5 micron HEPA filter. It works just fine, even with 50 feet of 2.5 inch hoses to my Clarke Floor Crafter. Don’t get me wrong I do like their concept, it just wasn’t for me.
View finns's profile
finns
164 posts in 3112 days
#3 posted 11-09-2014 01:15 AM
Hairy,
I purchased this set up over a year ago for my DC. Seems to work well. Loosen the ring and set the cyclone on the floor to empty. I chose this as I don’t move my DC around the shop and have a smaller metal cyclone/shop vac for other tools. I went with metal as I grew tired of the plastic cyclones coming apart.
hairy
#4 posted 11-09-2014 04:12 AM
Loosen the ring and set the cyclone on the floor to empty. I went with metal as I grew tired of the plastic cyclones coming apart.
- finns
I thought it was that way, for how you have it set up. Thanks! The other pic style looks like more work. Un hook, at least, the top hose to remove the cyclone/can together from the cart. For me,that would get old quick, especially with a 17 gallon can. I guess that gets down to how much stuff you have to collect with it. Maybe it just looks worse than it really is. I’m getting increasingly lazy.
Tell me more about the plastic cyclone coming apart. Is it where the cyclone attaches to the can? Oneida sells braces to keep the cyclone from flexing. They shouldn’t be too hard to fabricate at home.
I’ll probably hook it up like you did. It stays in one place.
Paul, that sideways pic is killing my old neck. I downloaded it to flip sideways to get a good look. Thanks!
paulhf, I know what you mean about it wasn’t for me. I bought a belt/disc sander that had great reviews, and I hate it. The real issue I’m having here is that I can’t go see 1 in person, I’m going by what I see on the web.
Thanks fellas!
View Paul's profile
Paul
#5 posted 11-09-2014 05:14 AM
Here is a bit better shot. Like finns it’s a simple loosen a metal piece put the cyclone on the ground empty and put back, its really simple and takes no time at all. I opted to not buy the dust bin from oneida and source a fiber bin for myself for a bigger receptacle and drill the top to fit the cyclone.
in retrospect i would have gone with a 50+ gallon fiber bin for collection, mine is a 25 gallon and fills up fast.
Paul
View Roger's profile
Roger
20928 posts in 2800 days
#6 posted 11-09-2014 01:25 PM
The plastic one that I have made a huge improvement. I still need to do some other things, like, add a Wynn filter eventually down the road. My only complaint was the size of the ports. I had to “fab” up the fittings to work. It took some extra time, but, well, it is what it is. I think many companies out there make their own size things and that makes it difficult for us peons. Most fittings at the big box stores won’t fit without some sort of “fabrication”. Whatever you decide will definitely improve your dc. Good luck on a BF sale..
View WhyMe's profile
WhyMe
1012 posts in 1557 days
#7 posted 11-09-2014 02:24 PM
My SDD is separate from the DC and is on wheels.
View sawdustjunkie's profile
sawdustjunkie
383 posts in 1713 days
#8 posted 11-17-2014 04:22 AM
WhyMe: I have the super Dust deputy, but on a 30 gal trash can.
The can you have it on will fill up real fast.
When I run the planer, I can get the 30 gal can to 3/4 full in about a hour’s time.
I am actually looking to get a larger can to mount it on, but just don’t know where to get one cheap.
-- Steve: Franklin, WI
WhyMe
#9 posted 11-17-2014 03:21 PM
When I run the planer, I can get the 30 gal can to 3/4 full in about a hour s time.
I am actually looking to get a larger can to mount it on, but just don t know where to get one cheap.
- sawdustjunkie
I know what you mean, but I don’t do a lot of power planing, mainly tablesaw, bandsaw and sander use, so that 13 gal container doesn’t fill too fast. I’m not a heavy wood worker, so I may have to empty it once a month. I was using a 30 gal trash can but wanted something a little more compact.
hairy
#10 posted 11-17-2014 03:38 PM
I hit the jackpot on craigslist. $10 for the barrel, 5 miles away. He was going to do what I’m doing, and changed his plans. I made a mobile base out of re – used lumber, the rest is on order.
Thanks for all the good advice.
View Marv88's profile
Marv88
84 posts in 1895 days
#11 posted 11-23-2014 04:57 AM
Here’s mine with a Delta 50-760. I made an adapter for the 6” to 5” transition and use a wide rubber band to seal it. To empty all I have to do is slide the Dust Deputy up (it stays up with a Velcro strap attached to the stand) and pull the drum out.
v
-- "Post count on a forum does not denote level of knowldege, skill nor experience"
