DW 708 SCMS Adjustment.
Forum topic by Gerald Thompson posted 11-07-2014 12:06 PM 897 views 0 times favorited 2 replies Add to Favorites Watch
Gerald Thompson
852 posts in 2107 days
11-07-2014 12:06 PM
I have managed so adjust the saw blade to 0 degrees and 45 degrees to the left but cannot get the blade to 45d to the right. The adjustment bolt is below the right adjustment bolt for the 0 degree scale. I have adjusted it and the degree pointer will only move about 10d maximum. If I kept turning it it seems as if the bolt would come out completely before 45 degrees was achieved.
By left and right adjustments I mean from the aspect of standing in front of the saw and the degree pointer would be left or right not the blade itself.
-- Jerry
2 replies so far
View duc996's profile
duc996
19 posts in 1370 days
#1 posted 11-07-2014 01:43 PM
Jerry, are you trying to bevel 45 degrees to the right? I have the same model and if you are trying to do that then look towards the back of the machine. There is a black plastic arrow piece that you have to press for the unit to bevel to the right. I hope that is what you were asking.
Gerald Thompson
#2 posted 11-07-2014 02:47 PM
Ah so! Yes it works. I don’t care what they say about you, you are OK.
Thank you.
Jerry
-- Jerry
