adding a bread board end to a cutting board
« back to Joinery forum
Forum topic by wiser1934 posted 11-06-2014 02:43 AM 987 views 1 time favorited 3 replies Add to Favorites Watch
View wiser1934's profile
wiser1934
524 posts in 3175 days
11-06-2014 02:43 AM
Topic tags/keywords: dowel pins bread board ends
i saw at some point that someone used a dowel pin(s) to attach the end on. used 3 dowel pins and only the center one was glued in place. any one have any info on doing this??? thank you, paul
-- wiser1934, new york
3 replies so far
View bobro's profile
bobro
320 posts in 1338 days
#1 posted 11-06-2014 09:53 AM
Well that’s the classic breadboard end, a great construction to both allow sideways movement while clamping down on cupping, therefore often used on tabletops.
-- Lao Ma: You are so full of anger and hatred. Xena: Everybody's gotta be full of something.
View Paul Miller's profile
Paul Miller
33 posts in 3481 days
#2 posted 11-06-2014 04:16 PM
The outside dowels holes are elongated in the tongue to allow for wood movement. Only the center hole is a tight fit and glued.
View WhyMe's profile
WhyMe
1025 posts in 1589 days
#3 posted 11-06-2014 04:59 PM
You also want to use drawborded mortise and tenon method.
http://www.finewoodworking.com/how-to/video/drawbored-mortise-and-tenon.aspx
