Forum topic by JMott | posted 11-05-2014 10:29 PM | 1076 views | 0 times favorited | 8 replies | ![]() |
My wife has been asking for a while for me to build her a large chalk board framed by some reclaimed barn wood I found a while back. The chalkboard will be made by priming and chalkboard painting a piece of 4’ x 6’, 3/16” hardboard. My question is what is the best way to frame the hardboard? My first thought was to simply cut slots in the frame and “float” the hardboard like a panel in a cabinet door. The other option is to rabbit the frame 3/16” and flush mount the hardboard with the back of the frame. Neither way is any more difficult or time consuming than the other, but I thought I’d ask if anyone has an opinion one way or the other. Thanks! |
8 replies so far
#1 posted 11-05-2014 11:05 PM |
I would cut a rabbit to fit -- Ken |
#2 posted 11-06-2014 12:08 AM |
+1 for the rabbet. That way if something should ever damage the hardboard, it can be easily replaced. -- Art |
#3 posted 11-06-2014 04:29 PM |
What would concern me more than the joinery in your plan is that 3/16” hardboard is going to flex pretty good when somebody is writing on it with chalk unless it is pressed firmly against a wall. A rabbet and a frame is a good plan, but you will have to attach the 3/16” hardboard to the wall independently of the frame (probably with some sort of construction adhesive.) -- Jesse Felling - http://www.fellingstudio.com |
#4 posted 11-06-2014 05:50 PM |
Here ya go. I built a frame for a tile mosaic my wife put on the wall above and behind our stove in the kitchen. I think the same principal would apply. Cut a rabbet and attach the blackboard to the frame. Hope this helps. -- Handcrafted by Mike Henderson - Channelview, Texas |
#5 posted 11-06-2014 06:56 PM |
I would cut a slot, if anything were to happen to the board itself, it would likely need only paint + you don’t have to fasten it with anything. I usually reserve rabbets for a frame that would hold glass and have a greater chance of complete destruction necessitating replacement. |
#6 posted 11-06-2014 07:11 PM |
I don’t believe it really makes a lot of difference. The slot design may make the entire assembly a bit more rigid, counting on the additional integrity of the board rather than just the frame itself, if the board isn’t mounted quite firmly in the rabbeted area. I’m curious how you plan to join the corners of the frame. |
#7 posted 11-06-2014 08:45 PM |
Thanks for the responses. Jesse – I agree that the hardboard might have some flex when writing, but I’m not too concerned because it will primarily be a decorative piece. My wife also decided she wants it 3’ x 6’ instead of 4’ x 6’ which will help with the rigidity. Yonak – I plan to glue and v nail the miters. |
#8 posted 11-07-2014 04:40 AM |
Then I would choose the slot method for rigidity’s sake. |
Forum | Topics |
Woodworking Skill Share
12026 |
Woodturning
2102 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1369 |
Finishing
4899 |
6689 |
28034 |
CNC Woodworking
211 |
Hand Tools
5403 |
Jigs & Fixtures
1417 |
Wood & Lumber
6223 |
1387 |
Focus on the Workspace
2152 |
1185 |
Woodworking Trade & Swap
4753 |
LumberJocks.com Site Feedback
2197 |
Coffee Lounge
8842 |
