Jessem Rout-R-Lift
Forum topic by Grant Davis posted 11-05-2014 07:23 PM 1444 views 0 times favorited 0 replies Add to Favorites Watch
View Grant Davis's profile
Grant Davis
770 posts in 3870 days
11-05-2014 07:23 PM
New in the box JessEm Rout-R-Lift FX router table insert with precision height adjustment. This lift has never been used or even had a router installed in it. The lift comes with the adjustment handle, starter pin for free hand routing, 1.5” lock tab ring and also the additional set of 4 piece insert rings (set includes 1/4, 1/2, 1-3/8 and 2-1/2 diameter rings). 1-3/8 ring accepts guide bushings for inlay routing.
Reinforced 9-1/4” x 11-3/4” CNC machined phenolic top plate
Threaded spindle runs on two double-sealed ball-bearings
Dedicated cam-lock mechanism prevents spindle rotation
Sized for the popular 3-1/2” diameter fixed-base router motors
Features Tab-Loc insert ring design and built-in table snuggers
If you are building your own router table or table saw extension for a router table, you won’t find a better insert for the price. This thing will last a lifetime.
Asking $220 + shipping
-- Grant...."GO BUCKEYES"
0 replies so far
