Bevel Saw Blades
Forum topic by Kevin posted 11-05-2014 01:27 PM 1033 views 0 times favorited 9 replies Add to Favorites Watch
View Kevin's profile
Kevin
466 posts in 3446 days
11-05-2014 01:27 PM
Topic tags/keywords: saw blade blade
Got a quick question.
I recently acquired several 10” saw blades that a cabinet company were no longer using. Here are the details about the saw blades.
1” arbor
60T
Each blade is extremely heavy and thick. Measures 1/4” thick
Around the arbor are 5 smaller holes which are countersunk on one side for what looks like small bolts.
Each tooth is beveled in the same direction. If you were to put it on the saw the bevel would run from top left to bottom right.
Does anyone know what these blades went on? Was getting some extra blades for my table saw and miter saw, but when I inspected them more closely I wasn’t for sure. They were free and in excellent shape, been re-sharpened and everything :)
No pictures unless needed then when I get home I can post some.
Thanks,
Kevin
-- Williamsburg, KY
9 replies so far
View johnstoneb's profile
johnstoneb
3072 posts in 2413 days
#1 posted 11-05-2014 01:39 PM
Without pictures its hard to say but are they for a gang saw.
-- Bruce, Boise, ID
Kevin
#2 posted 11-05-2014 02:01 PM
This is what the blade looks like, but it has the protective rubber coating on the teeth and dust all over it. The ones I have look almost new.
I believe this is the back side and the front are counter sunk on those smaller holes.
kevin
-- Williamsburg, KY
View ChrisK's profile
ChrisK
2017 posts in 3322 days
#3 posted 11-05-2014 02:26 PM
I think Bruce is correct, they are from a gang rip saw.
-- Chris K
View Nubsnstubs's profile
Nubsnstubs
1435 posts in 1971 days
#4 posted 11-05-2014 03:28 PM
I had a 1/4” x 10” blade with 3/8” teeth made for cutting the female sliding dovetail on drawer sides. When mounted in the saw, the teeth are as you described. On the blades you just got, all you would need to do is get a 1” x 5/8” adapter to fit your saw if that’s your arbor size. I don’t think the holes would present a problem unless the saw plate is thin.
You did mentioned 1/4” thick. Is that the plate or is it the teeth? ................. Jerry (in Tucson)
Kevin
#5 posted 11-05-2014 03:51 PM
Thanks guys,
I’m pretty sure the teeth and plate are 1/4” or really close to it. I know they are extremely sharp (lol) and the blade is much heavier and thicker than my other full kerf blades.
I’ll post a pic of my blade when I get home of different angles also.
I did find some 1” to 5/8” arbor adapters on amazon at a pretty good deal that would work. Just trying to figure out if these blades can used and what they were used for :)
Kevin
-- Williamsburg, KY
Kevin
#6 posted 11-06-2014 02:00 AM
Here are some pics of the saw blade. As you can see one blade has the teeth beveled to the left while the other blade they are to the right.
You can see from the pics how thick the blade is.
Kevin
-- Williamsburg, KY
runswithscissors
2928 posts in 2266 days
#7 posted 11-07-2014 12:48 AM
Is it possible they are the outside blades for a 10” diam. dado? I can’t figure out why a gang saw would want to make such a wide kerf, as that would be wasteful of wood. Admittedly, I have never used a gang saw.
Kevin
#8 posted 11-07-2014 01:19 AM
Looking at the with that perspective it would cut a dado with just one blade for 1/4 plywood. We have a gang rip saw at work, never took a close look at the blades on it, but I think on Monday I will though. True, it would be a lot of wood wasted.
Kevin
-- Williamsburg, KY
Nubsnstubs
#9 posted 11-07-2014 01:50 AM
Kevin, what is the angle on the blades? ........ Jerry (in Tucson)
