Finish options on Cherry
Forum topic by Joel_B posted 11-04-2014 11:36 PM 1194 views 0 times favorited 22 replies Add to Favorites Watch
View Joel_B's profile
Joel_B
342 posts in 1379 days
11-04-2014 11:36 PM
I am starting work on a cherry bed frame and looking for a finish with the following attributes:
1. Not extremely labor intensive.
2. Reduces or eliminates blotching.
3. Moderately durable.
4. Non toxic when cured, doesn’t smell for a long time while curing.
5. Natural looking
So far I have tried on some scraps Arm R Seal and thought it was just ok, I did get some blotching.
I used satin for all coats and now understand I should have used gloss for all coats except the last.
I bought a sample can of Waterlox because I liked some pictures of pieces done with it.
However I read that it can smell for 2 or 3 months while curing which is not an option in a bedroom.
I am thinking other option might be BLO, shellac or Charles Neil Pre Conditioner with just poly like general finishes top coat. I used top coat recently on some Baltic birch plywood and it like the stuff it is absolutely clear which may or may not be good in this case.
I am not trying to achieve the absolute best looking finish for Cherry, just one that is good enough and meets my criteria.
Thanks
-- Joel, Encinitas, CA
22 replies so far
View Minorhero's profile
Minorhero
373 posts in 2603 days
#1 posted 11-04-2014 11:47 PM
Arm-R-Seal works really well. The first coat on cherry always looks blotchy. Go back and do a 2nd and 3rd coat and you will find it very consistent looking. I used it recently for a dining room table and bench and it worked great. I also used satin.
View distrbd's profile
distrbd
2252 posts in 2445 days
#2 posted 11-04-2014 11:48 PM
Tung oil,that’s it,Cherry will get deeper in color as it ages.
-- Ken from Ontario, Canada
Joel_B
#3 posted 11-04-2014 11:58 PM
Tung oil,that s it,Cherry will get deeper in color as it ages.
- distrbd
What exactly do mean exactly by Tung Oil, there are many products that contain tung oil such as the Waterlox I mentioned. Additives are used to make it more durable, waterproof.
Maybe you are talking about pure tung oil like this?
http://www.leevalley.com/us/Wood/page.aspx?p=20049&cat=1,190,42942
Joel_B
#4 posted 11-05-2014 12:01 AM
- Minorhero
I did do at least 3 coats. Got a little bit of wiping marks and some dull areas. Some 340 grit between coats seemed to help. Maybe using the gloss and more practice would help.
View Case101's profile
Case101
107 posts in 1791 days
#5 posted 11-05-2014 12:03 AM
Check out waterlox
-- John, New Jersey
Joel_B
#6 posted 11-05-2014 12:15 AM
Check out waterlox
- Case101
I have sample can which i will be trying out soon.
Concerned about reports that it smells bad for months.
If I could I would just leave it to cure in the garage for a few months but it has to be in the bedroom asap.
distrbd
#7 posted 11-05-2014 12:27 AM
I’m not familiar with Waterlox.
I use Circa 1850 Polymerized tung oil which is most likely the same as :
http://www.leevalley.com/US/wood/page.aspx?p=20050&cat=1,190,42942
The table,kitchen island, I built 6 months ago is already deep red ,2-3 times darker than before,in my humble opinion ,cherry looks best on it’s own without any stains,dyes,etc.
I also has good result mixing tung oil with Spar varnish (50/50) and 25% paint thinner/mineral spirits.but it smells for a week.
Joel_B
#8 posted 11-05-2014 12:31 AM
The table,kitchen island, I built 6 months ago is already deep red ,2-3 times darker than before,in my humble opinion ,cherry looks best on it s own without any stains,dyes,etc.
- distrbd
Would it make sense to put a coat of poly over it to make it more durable / waterproof ?
I agree with the no stains or dyes.
View CharlesA's profile
CharlesA
3322 posts in 1796 days
#9 posted 11-05-2014 12:32 AM
There are lots of options, Arm-r-Seal shouldn’t be judged after a couple coats—and the cherry will darken and even out (with all blotching gone) significantly over a couple of weeks—and be beautiful. Cherry is a difficult wood to demand that it look in final form immediately.
Case101
#10 posted 11-05-2014 12:33 AM
Maybe thin out the poly into a wiping finish?
-- John, New Jersey
distrbd
#11 posted 11-05-2014 12:59 AM
- Joel_B
I will let others with more experience answer that question,I only know tung oil and spar varnish works and also gives some protection ,but the smell was not pleasant so it would not be advisable to apply it on a bed frame.
I would imagine WB poly could be used after a week or once the oil is dried.
View gfadvm's profile
gfadvm
14940 posts in 2688 days
#12 posted 11-05-2014 01:22 AM
I’m a big fan of shellac and find it MUCH more durable than others say. I might be hesitant to use shellac on a high use tabletop but otherwise I use it on most of my stuff. I rub all of my shellac on and find it an idiot proof finish.
Minorhero
#13 posted 11-05-2014 02:45 AM
Arm-R-Seal needs to be rubbed down with steel wool or very fine sand paper between coats. I used 0000 steel wool and that worked quite well.
runswithscissors
2751 posts in 2023 days
#14 posted 11-05-2014 02:59 AM
I like water based acrylic. Dries to touch in 1/2 hour, recoat in 2 hours. You have to sand lightly between coats, as it raises the grain. It has a very mild odor that goes away quickly. I used semi gloss on my oak kitchen cabinets, and it has been very satisfactory. Spray or brush
View Duckster's profile
Duckster
358 posts in 1349 days
#15 posted 11-05-2014 03:45 AM
I use a sealer and then 4 or 5 coats of lacquer.
-- Duckster, Texas. {Any day of fishing, Beats a good day at work.} Wash your feet and love Jesus
