Center Undermounted Drawer Slide
Forum topic by EdsCustomWoodCrafts posted 11-02-2014 09:58 PM 819 views 0 times favorited 5 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
766 posts in 1311 days
11-02-2014 09:58 PM
Yet another question that I can’t find an answer to!!
I’m building 4 drawers and I want to use a center Undermounted drawer slider but I don’t know how long it needs to be!!
I have an width of 17 1/4” so do I find a slider that is bigger and then adjust it to the length I need?? And if you can recommend a cheaper version they all look to be $10 each and I have 4 drawers
Thanks
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
5 replies so far
View mahdee's profile
mahdee
3874 posts in 1735 days
#1 posted 11-02-2014 11:46 PM
Maybe make your own? I made these over 24 years ago and they are still very functional.
-- earthartandfoods.com
EdsCustomWoodCrafts
#2 posted 11-02-2014 11:59 PM
Sorry just want to buy this component !! Need to focus on bigger fish like the actual router table , lol
View RobS888's profile
RobS888
2406 posts in 1813 days
#3 posted 11-03-2014 12:10 AM
Measure from the front edge of the face frame back, the ones I have used use a t shaped plate that has some flexibility in positioning it at the back and attach to the face frame. You could even go an inch less and it will still work out.
Edit:
I used these in the kitchen.
http://www.rockler.com/accuride-center-mount-slide-for-face-frame-cabinets-series-1029-select-length
About $8, but only rated for 35lbs.
On the second page/tab you can see a link to a spec sheet that shows the depth range for each size .
-- I always suspected many gun nuts were afraid of something, just never thought popcorn was on the list.
mahdee
#4 posted 11-03-2014 12:17 AM
40 cents vs. $40 was my solution.
View timbertailor's profile
timbertailor
1594 posts in 1392 days
#5 posted 11-03-2014 09:15 PM
Generally, you get the one closest to the full length of your drawer as you can, as long as it is not longer.
You may lose a couple of inches of pull out but most people live with it. Full extension slides are more expensive.
